Method to show CPTONE configurations on VG224
Does anyone have a way to show all the frequencies, durations, cadences, etc. that are defined by the default cptone country selections?
Some values can be found via "show voice port 2/X", but I'm looking to confirm the actual frequencies used, cadences, etc.  Something like a "show cptone GB detail" command.
1 ACCEPTED SOLUTION
Maybe this will work:
test voice tone
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_t1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1645172
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
test voice tone
Jorge Armijo
Thank you, Jorge. That is exactly what I was looking for.
Hi Ray,
I'm glad I could help.
Thanks for the rating and good luck
Jorge Armijo
423
