MGCP and H323 on same gateway
Is it supported to have MGCP and H323 running on the same gateway controlled by CM 6.1 at the same time.
fxo --> h323 controlled
fxs --> mgcp controlled
Re: MGCP and H323 on same gateway
Yes, this is possible and supported.
Brandon
Hybrid gateways are common. I assume you want caller-id on the FXOs which is the reason you are using H323? There are pros and cons to use one or the other. Some times you just grab some advantages of one gateway type and some of advantages of the other.
we have a little doc with a comparison in case you want to take a look at it:
MGCP and H.323 Voice Gateway Protocol Comparison
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00806fedbe.shtml
And as mentioned this is a really common scenario in which you mix H323 and MGCP
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Yes it is for caller ID support.
But i will have a 4 port fxo card. Ports 0, 1 2 will be h323 controlled , port 3 will be mgcp.
And then I will have a 2 port fxs controlled as mgcp which will only use the fxo controlled port for out bound calls.
841
