MGCP application high utalization on cisco router
                   Hi All,
I am facing issue with MGCP application high utalization on cisco router it is showing 67% in 5 min. there are for analog lines are connected on router and no PRI configured on this router
How can i resolve this issue .
1 restart router is one option ......tell me other options pz see attached file.
Hi Prashant.
Which ios version are you running.
Have you tryed with a no mgcp to shut the mgcp and see if the cpu goes ok?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
VIP Purple
Hi Prashant,
In addition to what Mr. Carlo has asked, do share router model and show inventory.
regds,
aman
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.0(1)M4
BANLANWR02#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V09 ,
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW         , VID: V01 ,
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 1", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T           , VID: V02 ,
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 ,
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 ,
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 ,
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 ,
Re: MGCP application high utalization on cisco router
Hi Prashant,
please send the output of a show voice call status and a show proc cpu history.
A show run would be also  helpful
Carlo
VIP Purple
Hi Prashant,
I was trying to check any issue related to this IOS but could not find any .
Can u please try upgrading the IOS to 15.0(1)M10 during maintenance hours and check?
regds,
aman
we have one backup router same as it is configration and also in production ..but there is no such type of issue..
so please explain  why we need  upgrading the IOS to 15.0(1)M10
Hi Prashant.
I also asked a show running and a show voice call.
Can you please post it
Carlo
VIP Purple
Hi Prashant,
the only idea to do upgrade was to,  since u are running the old IOS in maintenance delpoyment modea nd fater that many releases have come.
can u configure process cpu statistics limit entry-percentage number [size seconds] with percentage as 40 and size as 300 and then run the command show process cpu history table if we can help u further.
regds,
aman
170
