Community Member
MGCP between CallManger 4.2(3) and Gateway 2851 with 5 E1s B-ch OOS
HELLO EVERYBODY.
I have some problems between CallManager 4.2(3) and gateway 2851 with 5 E1s, I see that the gateway register to CallManager but I receive alarms on the EVENT VIEWER of the CCM that all E1s that the b-channel out of service, also there is an Transient connection attempt with the following explanation:
A conection was established and immediately dropped before completion registration. Incomplete registration may indicate a device is rehoming in the middle of registration.
Here is a show ccm, where you can see the registration ok:
MGCP1_GW#show ccm
MGCP Domain Name: MGCP1_GW.promerica.com.gt
Priority Status Host
Primary Registered 10.4.0.55
First Backup None
Second Backup None
Current active Call Manager: 10.4.0.55
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 17:17:14 GUATE Sep 29 2008 (elapsed time: 00:00:36)
Last MGCP traffic time: 17:17:50 GUATE Sep 29 2008 (elapsed time: 00:00:00)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.4.0.55
Current Link State: OPEN
Statistics:
Packets recvd: 26067
Recv failures: 0
Packets xmitted: 33114
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, port 0
Slot 0, port 1
Slot 0, port 0
Slot 0, port 1
Slot 0, port 0
Configuration Auto-Download Information
Current version-id: {C090D148-22AA-4CCC-B51E-5953CB68E64A}
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 16
Download Successful : 16
Download Failed : 0
Configuration Attempted : 8
Configuration Successful : 8
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
Configuration Error History:
controller E1 0/2/0no pri-group timeslots 1-31
controller E1 0/1/1no pri-group timeslots 1-31
controller E1 0/1/0no pri-group timeslots 1-31
controller E1 0/0/1no pri-group timeslots 1-31
controller E1 0/0/0no pri-group timeslots 1-31
FAX mode: cisco
MGCP1_GW#
Enclosed the EVENT VIEWER MESSAGES
Walter Flores
Community Member
Re: MGCP between CallManger 4.2(3) and Gateway 2851 with 5 E1s B
TWO MORE EVENT VIEWER MESSAGES.
REGARDS
WF
Silver
How many E1/T1 do you have working in the router, It could be that the config. in the CCM shows the other spare controllers but they are not configured.It seems that the router is trying to register all the controllers
Community Member
I have 5 E1s ports on router are 0/0/0, 0/0/1,0/1/0, 0/1/1 and 0/2/0, also the configuration on CCM has the same E1 ports enable.
WF
123
