Community Member
MGCP Caller ID problem
We just upgrade our callmanager to the version 7.0.2.1000-18 to solve a problem with MGCP.
We are now receiving the Caller id in the gateway but not at the receiving end.
Here is the debug from the gateway
Mar 19 00:19:19.579: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808317
Exclusive, Interface 0, Channel 23
Display i = 'Bell Canada'
Calling Party Number i = 0x0081, '5143436111'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '5147345055'
Mar 19 00:19:19.683: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8001
Channel ID i = 0xA98397
Exclusive, Channel 23
Mar 19 00:19:21.027: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x8001
Progress Ind i = 0x8088 - In-band info or appropriate now available
Mar 19 00:19:21.387: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x8001
Mar 19 00:19:21.391: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0001
Mar 19 00:19:33.031: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0001
Cause i = 0x8090 - Normal call clearing
Mar 19 00:19:33.067: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8001
Mar 19 00:19:33.091: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref
All the possible option are selected in the callmanager.
Does somebody have a idea?
Re: MGCP Caller ID problem
That's rough. The Display IE is in there, but it's not showing up on the PSTN.
I would see if you have any old debugs of isdn from your other version, and do a 'stare and compare' on it.
Otherwise, you can try changing the Plan and Type of your calling number, but that's mostly a guessing game.
-nick
Hall of Fame Super Gold
In North America, usually you must set plan/type as ISDN/national in order for telco to accept your calling number.
264
