MGCP CCM 5.x Router2811 NOT REGESTERING
labredes1
I can not register de MGCP with the CCM 5.x
I always get the message Regestering with CM, but the MGCP never registers.
Can anyone help me?
In attacth there are the running config of the router(MGCP), and MGCP debug.
Anyone?
Thank you
Andre' Santos
He has his hostname on the gateway set to "router".
That is most likely what the CM is seeing.
6 Replies 6
Rob Huffman
Hi Andre,
It's likely the Domain name issue outlined in this doc (I noticed that your config is set at the default - router);
MGCP Gateway Registration Failure with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml#prob
Hope this helps!
Rob
bgibson
Change your hostname to something unique.
Make sure the hostname is the same inside of CM.
That is how CM knows how to register the gateway. What is happening right now is your router is sending the requests to the CM but the CM doesn't know what to do with them.
jbarcena
Level 9
Level 9
Check the Application log in the CCM server, that's how you can see which name is the CCM receiving and just use the exact same name in the GW configuration page.
in the CCM i put the ip address of the gateway and not the domain name... Might this be the problem?
I don't know how to see the application log on the CCM...
Andre' Santos
Hi again,
that was the problem...I realy had to have the host name instead of the ip address of the gateway,although i thought it be better to use IP.
Thanks a lot all of you
André Santos
