Community Member
MGCP commands got erased
Hi i have a callmanager 4.1 that has 2 fxs and 4 bri registered using MGCP. The problem is that the mgcp commands that associate this interfaces to the call agent got erased suddenly loosing connection qith the callmanager.
Do anyone had this problem before, thanks in advanced.
Pepe
1 REPLY
Re: MGCP commands got erased
by any chance did you erased the GW in CUCM and had configured the ccm-manager config??
was that the only part that was lost?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
103
