mgcp config server
folks,
when configuring the gateway with mgcp, what information gets downloaded to the gateway in xml file, is it the dialplan?
if i do not use the command "mgcp config server" would i have to reset the gateway by issuing "no mgcp" ,"mgcp" command, what will this do?
VIP Super Bronze
Re: mgcp config server
Take a look at this link, you will get a good explanation on MGCP configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b70.shtml
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
most of the configuration that gets downloaded is in reference to dial-peers for the interfaces so they are created with application mgcpapp
if you do not issue mgcp config server you will need to to the whole configuration manually on the GW
if you issue no mgcp / mgcp you shut the MGCP process running in the gateway which means won't listen to anything in ports 2427 and 2428, thus the gateway will show unregistered until you issue the MGCP command again
that is mostly used when you have registration issues between CCM and GWs
java
if this helps, please rate
www.cisco.com/go/pdi
539
