MGCP configuration download not working
I have a problem with ccm-manager config command where it says that configuration is successfully downloaded, but configuration attempted stays to 0. As a result I have to manually insert the mgcp commands (e.g mgcp-call agent and redundant host). This output is along with the manual config. If I dont do manual config, there will be no call-agents listed although auto config download was successul.
Any input will be much appreciated.
Toor
GW01-2811#show ccm
MGCP Domain Name: GW01-2811
Priority Status Host
Primary Registered 70.95.19.12
First Backup Backup Ready 70.95.19.11
Second Backup None
Current active Call Manager: 70.95.19.12
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 14:15:06 EST Feb 28 2008 (elapsed time: 00:00:07)
Last MGCP traffic time: 14:15:06 EST Feb 28 2008 (elapsed time: 00:00:07)
Last failover time: 10:08:38 EST Feb 26 2008 from (10.95.19.12)
Last switchback time: 10:09:08 EST Feb 26 2008 from (10.95.19.11)
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 10:09:11 EST Feb 26 2008
Last MGCP Fallback end time: 10:10:46 EST Feb 26 2008
MGCP Download Tones: Disabled
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 5
Download Successful : 5
Download Failed : 0
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
FAX mode: cisco
Configuration Error History:
Re: MGCP configuration download not working
Do you have both of the following commands?
ccm-manager config server
ccm-manager config
Brandon
Yes both of these commands are in there.
Also I have tried inserting them over and over again.
The download attempt keeps on increasing
but configuration attempt stays at ZERO (0)
Thanks for your help
Please let me know if you have clue.
Toor
359
