Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MGCP Configuration error
Hello everyone!
I am  trying to configure MGCP on Cisco Router with E1 card and CUCM. I have  done it several times before, but this time E1 is not connected yet.
However, I am pretty sure that I should be seeing router's IP address on CUCM in the Gateway Section
show mgcp statistics shows me this strange failed messages:
IP address based Call Agents statistics:
IP address 192.168.x.x, Total msg rx 7,
                 successful 0, failed 7
What is this? And should I see my router's IP address on CUCM eventhough E1 is not connected?
debug mgcp error:
Sep 30 08:37:58.675: cmapp_mgr_process_ev_active_host_failed: Active host 0 (192
.168.246.6) failed
Sep 30 08:37:58.675: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]I
nvalid parameter (pkt 0x300086A0 pkt->mgcp_parm_lines 0x0)
Sep 30 08:38:28.675: cmapp_mgr_process_ev_active_host_failed: Active host 0 (192
.168.246.6) failed
Sep 30 08:38:28.675: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]I
Thank you!
P.S. One more thing I noticed regarding TFTP:
Sep 30 08:40:01.159: cmapp_xml_tftp_download_file: Unable to read file tftp://19
2.168.246.6/Azans_vgw.cnf.xml, rc=-2
Sep 30 08:40:01.159: cmapp_xml_get_xml_file: Could not read file tftp://192.168.
246.6/Azans_vgw.cnf.xml, len = 0
Sep 30 08:40:01.159: cmapp_xml_tftp_download_file: Unable to read file tftp:///A
zans_vgw.cnf.xml, rc=-2 ccm-manager confi
Sep 30 08:40:01.159: cmapp_xml_get_xml_file: Could not read file tftp:///Azans_v
gw.cnf.xml, len = 0
gw.cnf.xml, len = 0
Sep 30 08:40:01.159: cmapp_xml_exec_fsm: New state = CMAPP_XML_FILE_DNLD, ep = 2
A2DD130
Sep 30 08:40:01.675: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]I
I am using IP addresses, no DNS for now. Is it going to be a problem?
VIP Purple
Hi ,
regarding your TFTP problem, can  u share the show ccm-manager and show run from router?
also, share snapshot of show gateway config from CUCM.
regds,
aman
I have added router's name to DNS, not I can see the end points Unregistered (which is fine, E1 is not connected yet), but the gateway's status in CUCM is still unknown under IP address column
hostname Voice
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
isdn switch-type primary-net5
trunk group Telco_out
hunt-scheme round-robin
crypto pki trustpoint TP-self-signed-3098560452
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3098560452
revocation-check none
rsakeypair TP-self-signed-3098560452
crypto pki certificate chain TP-self-signed-3098560452
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303938 35363034 3532301E 170D3133 30333036 31393436
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30393835
  36303435 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A959 59FA6C77 884ABCE2 5EE87969 FF9C33E1 9035A360 12CBC6D1 FEFE9066
  19C306AD 593D776C F9412E59 85A9DE07 7D3FF526 BCDA25CC 7E4F911E 042C77D7
  B3BE33CA 13B484BE 897DEDB2 25CFE7A3 620E7B73 A1EFBB99 C5541297 FA6DBD07
  444B0210 02949478 B0744481 FFB0203A 20F248E3 43275A0E 283ED3D9 9041A002
  04F10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B1E232 35F97EA5 0CCCFCBB 92D91657 91CF6384 20301D06
  03551D0E 04160414 B1E23235 F97EA50C CCFCBB92 D9165791 CF638420 300D0609
  2A864886 F70D0101 05050003 81810062 D01B98AD B9447BAE 70815CEA 24521792
  8CF35F85 3C53D560 59E33377 E77B0011 499B7CD6 981F11A7 31872A9D AA6F8467
  B72DA077 5F0E8F4F ABDC00B5 871754AB 9EECBA8D DAA65659 CCB1F305 42FC4661
  4E2DF4D9 D6EB4358 89B9418B 61BEC80F C63DDBCA 0B77D669 B67C72EF BDA352CF
  E73A03CA 3DE3BB66 1D6B76DE 552B77
        quit
voice-card 0
codec complexity medium
dsp services dspfarm
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g723r53
codec preference 4 g723r63
codec preference 5 g723ar53
codec preference 6 g723ar63
codec preference 7 g711ulaw
codec preference 8 g711alaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g723r53
codec preference 6 g723r63
codec preference 7 g723ar53
codec preference 8 g723ar63
application
service Karsilama flash://TCL.tcl
  param pilotno 1111
  param alerttimeout 30
license udi pid CISCO2911/K9 sn FCZ16337UYJ
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
pri-group timeslots 1-12,16 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 192.168.1.10
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.1.10
control-plane
voice-port 0/0/0:15
voice-port 0/0/1:15
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.11
ccm-manager config
mgcp
mgcp call-agent 192.168.1.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dspfarm profile 7 mtp
codec g711ulaw
maximum sessions software 100
associate application SCCP
shutdown
gatekeeper
shutdown
line con 0
line aux 0
scheduler allocate 20000 1000
end
Voice#
TFTP problem is now gone as well btw
VIP Purple
You connect the E1 and if it is UP, u should see Gateway : Voice , Registration :REGISTERED WITH Cisco Unified Communications Manager hostname of Server , IP address  : LAN Router under Device Gateway.
regds,
aman
Snapshot
Usually these erors are associated with the name not matching.
If I were you - set the hostname
hostname VoiceRouter
set the domain
ip domain name MyDomain.com
so now make sure the device is defined on call manager
voicerouter.mydomain.com
You need to ensure that the router is sending the exact name defined on call manager.
Bronze
Gateways always show an unknown IP address. Only the endpoints report IP address and registration status.
Gareth
you should add the MGCP gateway by Hostname of the voice gateway
the name should be "Voice" and since i dont see any domain name configured on the router , so simply hostname will work
please send the " Show isdn status " out put as well,
Anurag Siddhu
802
