MGCP configuration issue (isdn --> invalid input)
Hi all,
I have a 2801 router. I inserted a VWIC2-1MFT-T1/E1 card. I configured it on a CUCM 7.1 by adding a new gateway using MGCP (I want it work using QSIG).
On the router I inserted the following commands:
no ip domain-lookup
mgcp
ccm-manager config server 172.17.7.5
ccm-manager config
exit
wr mem
After inserting these commands I could see the following debug:
Loading MU-GW-2801.cnf.xml from 172.17.7.5 (via FastEthernet0/0): !
[OK - 4749 bytes]
MU-GW-2801#
*Feb 10 11:43:57.786: %SYS-5-CONFIG_I: Configured from console by admin on console
This package type is not the default package type.
isdn switch-type primary-4ess
% Invalid input detected at '^' marker.
Could anyone help on what is the matter? I have tried several IOS:
   - c2801-adventerprisek9-mz.124-24.T2.bin
   - c2801-advipservicesk9-mz.124-24.T2.bin
   - c2801-entservicesk9-mz.124-24.T2.bin
I thought it could be that the command was not supported. But, none of these IOS worked.
Thank you very much,
JOSU
Bronze
Re: MGCP configuration issue (isdn --> invalid input)
There are alot more commands you need to add try
   pri-group timeslots 1-?? service mgcp
under controller interface
   isdn bind-l3 ccm-manager
under serial interface
then these addtional commands
  ccm-manager mgcp
   ccm-manager music-on-hold
   mgcp
   mgcp call-agent "IP address of callmanager "service-type mgcp version 0.1
   mgcp dtmf-relay voip codec all mode out-of-band
   mgcp modem passthrough voip mode nse
   mgcp package-capability rtp-package
   mgcp package-capability sst-package
   no mgcp package-capability fxr-package
   mgcp package-capability pre-package
   no mgcp timer receive-rtcp
   mgcp sdp simple
   mgcp fax t38 inhibit
   mgcp rtp payload-type g726r16 static
You need to make sure that in Callmanager the port says "registered" if it doesn't then you have the configuration wrong
Thank you very much for your answer markbatts
I discovered I had a problem. I saw this on the running-conf: "card type command needed for slot/vwic-slot 0/1".
So I introduced the command "card type e1 0 1". So, after that I saw "controller E1 0/1/0" on running. I was quite surprised not to see it before.
Afterwards I re-enter the commands:
   - mgcp
   - ccm-manager config server 172.17.7.5
I got this result:
[OK - 4757 bytes]
I checked the running-config and I saw these new lines:
isdn switch-type primary-5ess
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 172.17.7.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
no mgcp package-capability res-package
mgcp sdp simple
mgcp profile default
But when I checked on the CUCM I saw that it still appeared as "unregistered". So I selected the gateway and reset it. Doing so, I got these entries in gateway's console:
%Please configure network-clock-participate wic 1 first
%Insufficient resources to create pri-group - it has been removed
interface Serial0/1/0:15
What am I missing? I do not have any serial interface. Those commands are which you told me in your answer. Why should I have a serial interface. I am quite new in MGCP so every help is welcommed...
THANK YOU VERY MUCH
JOSU
Hi again,
I keep making some tries. The first line of the errors was:
So I introduced the command "MU-GW-2801(config)#network-clock-participate wic 1". Afterwards I reset the gateway from the CUCM and I got these error:
echo-cancel coverage 8
%At least one pri-group was configured already for E1 0/1/0
Please remove it before changing timing mode.
*Feb 10 17:35:38.979:  voice_port is not initialized
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:0, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:1, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:2, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:3, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:4, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:5, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:6, changed state to down
*Feb 10 17:35:39.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:7, changed state to down
*Feb 10 17:35:39.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:15, changed state to down
I can see now the serial interface. But, I do not know how to solve the pri-group issue..
THANK YOU!!!
JOSU
1764
