MGCP Configuration
I was configuring MGCP. Was adding new e1 PRIs. Added 4 PRIs successfully. But when adding 5th and 6th PRIs I am getting one error message. Is this highlighted error due to insufficient dsp rsource?
iec-v-gw-01(config-controller)#controller e1 0/2/0
iec-v-gw-01(config-controller)#pri-group timeslots 1-31 service mgcp
%Please configure network-clock-participate wic 2 first
%Insufficient resources to create pri-group - it has been removed
iec-v-gw-01(config-controller)#framing CRC4
iec-v-gw-01(config-controller)#linecode hdb3
iec-v-gw-01(config-controller)#clock source line
Fawaz
Hall of Fame Super Silver
MGCP Configuration
Fawaz,
2 things:
First ensure you define the wic with network-clock participate, i.e.
then, ensure you have sufficient DSPs, you can post your current conifig along with "sh inventory" for validation, and use the dsp calulator:
http://www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
HTH,pleae rate all useful posts!
Chris
MGCP Configuration
Thanks chris. It worked.
261
