Community Member
MGCP controlled 2821 and FXS to RightFax?
I have a CCM 4.3(1) with a 2821 running 12.4(11)T MGCP controlled. There are 3 PRI's coming into the system and 12 FXS ports tied to Caparis RightFax Server 9.X.
Calls come into CCM just fine and all call routing works even to the RightFax server through RL-->RG configuration that I have route patterns pointing to from within CCM.
Call Flow goes PSTN-->2821-MGCP(PRI)-->CCM(4.3(1))-->2821-MGCP(FXS Ports)-->Caparis-RightFax.
The faxes are getting to the server, however it is placing them in a default account because there is no DTMF being passed to it according to running the card in debug mode. So no ANI nor DNIS.
I was thinking of going to H323 to make this work if needed but would like to stick with MGCP if possible.
Should I switch the "MGCP" command from dtmf out of band to other parameters
or
Will I have to enable Fax-Relay and not passthrough to get this to see the DTMF digits ANI/DNIS?
Anonymous
N/A
Re: MGCP controlled 2821 and FXS to RightFax?
You can use DTMG relay.DTMF relay provides a way to transport DTMF digits in an RTP voice stream when the voice codec cannot accurately reproduce the digits, or the sender or receiver digital signal processor (DSP) cannot perform digit sampling. Each DTMF digit is encoded as an RTP named event packed, which is transmitted and received instead of the usual digit samples carried in voice packets. The named events are sent as RTP packets over UDP. The packets are encoded with a payload type which is negotiated during connection establishment between the GWs using SDP.
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087eb3.html#wp1028560
Community Member
I know this is a pretty old thread but I am having the same issue except I am running H323.   So my topology looks like thiis
DID from the PSTN over T1 >>> Cisco 2921 >>> FXS Port >>> RightFax Server
So calls rote over the T1 (4 digit DID) and I have a pots dial-peer pointed to the FXS port that the RightFax server is plugged into.  The Fax server nswers up but DID is never passed so the Fax is never routed to the intended recipient
because the routing code is always 0.
Green
Can you paste in your router config.
Alex
Regards, Alex. Please rate useful posts.
Community Member
APPVG1#sho run
Building configuration...
Current configuration : 6342 bytes
! Last configuration change at 11:13:07 EDT Mon Jul 25 2011 by tekadmin
version 15.1
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname APPVG1
boot-start-marker
boot system flash flash:c2900-universalk9-mz.SPA.151-3.T1.bin
boot-end-marker
card type t1 0 0
logging buffered 5000000
no logging console
no logging monitor
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip multicast multipath
no ip dhcp conflict logging
ip dhcp excluded-address 192.32.15.1 192.32.15.99
ip dhcp pool VOICE
   network 192.32.15.0 255.255.255.0
   default-router 192.32.15.1
   dns-server 192.32.11.11 192.32.11.37
   domain-name app.com
   option 150 ip 192.32.15.30
no ip domain lookup
ip domain name app.com
stcapp supplementary-services
port 0/2/3
  fallback-dn 3737
trunk group Copper
hunt-scheme round-robin
voice-card 0
voice service pots
voice service voip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
h323
  call preserve
  session transport udp
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
license udi pid CISCO2921/K9 sn FTX1522AH73
hw-module pvdm 0/0
archive
log config
  hidekeys
username tekadmin privilege 15 password 7 045558121B72470A584B56
redundancy
controller T1 0/0/0
cablelength long 0db
ds0-group 0 timeslots 1-24 type e&m-wink-start
ip ssh version 2
interface GigabitEthernet0/0
description ** Voice Interface **
backup interface GigabitEthernet0/1
ip address x.x.x.x
duplex auto
speed auto
no mop enabled
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
description Backup Interface
ip address x.x.x.x
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x
control-plane
voice-port 0/0/0:0
no vad
voice-port 0/1/0
description Paging Access
voice-port 0/1/1
trunk-group Copper
description 911 Backup
voice-port 0/1/2
trunk-group Copper
voice-port 0/1/3
trunk-group Copper
voice-port 0/2/0
description Customer Service Fax
station-id name 0128
station-id number 0128
caller-id enable
voice-port 0/2/1
description HR Fax
station-id name 3177
station-id number 3177
caller-id enable
voice-port 0/2/2
description Finance
station-id name 0557
station-id number 0557
caller-id enable
voice-port 0/2/3
timeouts ringing infinity
description Fax Test
caller-id enable
mgcp profile default
dial-peer voice 1000 pots
preference 1
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:0
forward-digits 11
dial-peer voice 1001 pots
preference 1
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:0
forward-digits 10
prefix 1
dial-peer voice 1002 pots
destination-pattern 9011T
port 0/0/0:0
prefix 011
dial-peer voice 1003 voip
destination-pattern 3[68]..
session target ipv4:x.x.x.x
incoming called-number .
voice-class codec 1
dtmf-relay h245-signal h245-alphanumeric
dial-peer voice 1004 voip
destination-pattern 3700
codec g711alaw
fax rate disable
dial-peer voice 1005 pots
description Inbound to RightFax
destination-pattern 37..
port 0/2/0
dial-peer voice 1006 voip
destination-pattern 3702
codec g711alaw
fax rate disable
dial-peer voice 1007 voip
destination-pattern 3703
codec g711alaw
fax rate disable
dial-peer voice 1008 pots
destination-pattern 9911
port 0/0/0:0
forward-digits 3
dial-peer voice 1009 pots
destination-pattern 911
port 0/0/0:0
forward-digits all
dial-peer voice 1010 pots
trunkgroup Copper
forward-digits 3
dial-peer voice 1011 pots
trunkgroup Copper
forward-digits all
dial-peer voice 1012 pots
destination-pattern 5000
port 0/1/0
forward-digits 0
dial-peer voice 2000 pots
description Cust Serv Fax
destination-pattern 0128
port 0/2/0
dial-peer voice 2001 pots
description HR Fax
destination-pattern 3177
port 0/2/1
dial-peer voice 2002 pots
description Finance Fax
destination-pattern 0557
port 0/2/2
dial-peer voice 2003 pots
destination-pattern 3737
no digit-strip
port 0/2/3
forward-digits all
gatekeeper
shutdown
banner motd ^CC
  * * * * * * * * * * * * * * Warning * * * * * * * * * * * * * *
  *  This system is restricted to authorized users for business *
  *  purposes. Unauthorized access is a violation of the law.   *
  *  This system may be monitored for administrative and        *
  *  security reasons. By proceeding, you consent to this       *
  *  monitoring.                                                *
^C
line con 0
line aux 0
login local
transport input ssh
transport output ssh
line vty 0 4
exec-timeout 20 0
login local
transport input ssh
line vty 5 15
exec-timeout 20 0
login local
transport input ssh
scheduler allocate 20000 1000
end
I opened a tac case amd the engineer did a pcm trace and verified that the digits were being sent.  I just don't understand why right fax doesn't see it.
The voice-port is 0/2/3 and dial-peer is 2003.  This is the one that the Right Fax server is plugged into
Green
From what I can see calls from the PSTN for RIGHTFAX are determined by a last 4 digits of 3737.
This should then forward to voice-port 0/2/3 which should be a DID trunk not an FXS.
voice-port 0/2/3
caller-id enable
no digit-strip
port 0/2/3
forward-digits all
Caller-id is not supported on DID trunk.
Could you try adding this:-
voice-port 0/2/3
shut
no timeouts ringing infinity
no caller-id enable
signal did wink-start
dial-type dtmf
no shut
Looking at google for RIGHT FAX it also states that you must have 3737 assigned to a user
http://www.scribd.com/doc/53713678/67/Appendix-B-Troubleshooting
Hope this helps
Alex
537
