Community Member
MGCP dial-peer issue
I am experiencing an issue with MGCP dial-peers in that when my router loses & regains the connection with Call Manager the MGCP dial-peers alter position in the running config.
e.g. :
Normal Operation
dial-peer voice 999100 pots
service mgcpapp
port 1/0/0
dial-peer voice 999101 pots
service mgcpapp
port 1/0/1
dial-peer voice 9 pots
destination-pattern 9[2-8].....
port 1/0/4
forward-digits 6
dial-peer voice 90 pots
destination-pattern 90..........
port 1/0/4
forward-digits 11
After router loses WAN link
port 1/0/4
forward-digits 6
port 1/0/4
forward-digits 11
service mgcpapp
port 1/0/0
service mgcpapp
port 1/0/1
The problem is highlighted by the fact that FXs ports are not controlled via MGCP & they look to the pots dial peers for out going access only.
I am running CCM ver 7 / router IOS ver 12.4(9)T7 / MGCP vere 0.1
I know I may require an IOS upgrade but I would be interested if anyone has experienced this.
Thanks.
Community Member
Re: MGCP dial-peer issue
Also the router is a Cisco 2811.
Community Member
we upgraded to 15.x on a 2811 and it fixed that issue.
For what its worth.
Community Member
Thanks Scott,
Did you experience the same problem, as I am struggling to actually find someone that has - starting to think it may be a config issue?
193
