MGCP Digit trace on Gateway
I have a 2801 router with a E1 voice registered with Callmanager. I'm having various issue when dialing out. When i place a call to the gateway i cannot see any isdn circuit beign picked up, i am using debug isdn q931 for this, but when i use the debug voice ccapi inout command i can see information coming into the gateway. How do i check for the correct digits coming into the gateway with this command or should i be using another command.
Green
Re: MGCP Digit trace on Gateway
ISDN q931 information is backhauled with MGCP...so if you want to see more info, I would recommend you to check CCM detailed trace.
Also debug mgcp packet is your friend. You wont see digits (unless CAS or analog) but it will show you if CCM is establishing any communication with GW, other useful command is debug ccm-manager backhaul packet.
Silver
When you do a 'show isdn stat' you won't see any Layer3 output. But you can use 'debug isdn q931' If you don't have output something is wrong configured.
If you want to see the channels used:
show voice call stat
or
show voice call sum
or
show mgcp connnection
You still won't see called and calling party though.
Example:
MGCP-GW1#sh isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 2
MGCP-GW1#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x137CD 2DC4 0x465F7DA4 0/0/1:15.4 0/2:3 g711ulaw 1/0
0x13849 2E02 0x465F7DA4 0/0/1:15.17 0/3:4 g711ulaw 1/0
0x13D93 30A7 0x465F7DA4 0/0/1:15.24 0/4:6 g711ulaw 1/0
0x13DA9 30B2 0x465F7DA4 0/0/1:15.25 0/3:1 g711ulaw 1/0
0x13DAB 30B3 0x465F7DA4 0/0/1:15.26 0/3:3 g711ulaw 1/0
0x13DAD 30B4 0x465F7DA4 0/0/1:15.27 0/4:2 g711ulaw 1/0
0x13DFD 30DC 0x465F7DA4 0/0/1:15.29 0/1:6 g711ulaw 1/0
0x13E0B 30E3 0x465F7DA4 0/0/1:15.30 0/3:5 g711ulaw 1/0
0x13E39 30FA 0x465F7DA4 0/0/1:15.31 0/1:4 g711ulaw 1/0
0x13F15 3168 0x465F7DA4 0/0/1:15.1 0/2:4 g711ulaw 1/0
0x13F63 318F 0x465F7DA4 0/0/1:15.2 0/1:5 g711ulaw 1/0
0x140A7 3231 0x463F0648 0/0/0:15.21 0/4:3 g711ulaw 1/0
0x140BD 323C 0x463F0648 0/0/0:15.28 0/3:2 g711ulaw 1/0
0x140BF 323D 0x463F0648 0/0/0:15.26 0/2:5 g711ulaw 1/0
0x140C9 3242 0x463F0648 0/0/0:15.30 0/1:2 g711ulaw 1/0
0x140CD 3244 0x463F0648 0/0/0:15.22 0/1:3 g711ulaw 1/0
0x140CF 3245 0x463F0648 0/0/0:15.29 0/1:1 g711ulaw 1/0
0x140D1 3246 0x463F0648 0/0/0:15.27 0/2:2 g711ulaw 1/0
0x140D3 3247 0x463F0648 0/0/0:15.24 0/3:6 g711ulaw 1/0
19 active calls found
MGCP-GW1#
MGCP-GW1#deb isdn q931
debug isdn q931 is ON.
MGCP-GW1#
*Jul 17 09:32:16.374: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x1D4E
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x00A1, '805257'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '992876949121445'
*Jul 17 09:32:16.498: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x9D4E
Hope this helps,
Jan
304
