MGCP DTMF relay
Hi all
online banking needs this command
mgcp dtmf-relay voip codec all mode cisco
Unity needs this command for psnt dial in
mgcp dtmf-relay voip codec all mode out-of-band
I am not aware of a way to run both on the same router? Thoughts? Missing something?
1 REPLY
Silver
Re: MGCP DTMF relay
Yes you can use this command mgcp dtmf-relay voip codec {all | low-bit-rate} mode {cisco | nse | out-of-band | nte-gw | nte-ca} with both the option on same Cisco router but you have to give priority to codec.
807
