MGCP E1 Configuration Difference between PRI T1
Hi Folks,
I am used to configuring PRI (T1)in North America. What do I need to watch out for When Configuring a E1 (multiple ones) on 3845 MGCP? This is a Configuration for Eurpe?
What should I watch out for regarding Dial Peers ?
I will have 2 E1 in one router?
Thank you.
Raj
Re: MGCP E1 Configuration Difference between PRI T1
the main difference is just the channels, since this is not H323 you're not going to define the dial-peers which would need port x/x/:15 but other than that they will be the same. also the basic config of the controller regarding the framing, etc but the telco usually tells you the values you need to set to match their end. also the isdn-switchtype will be provided by the telco depending on what they have, a quick call to the telco will give you all the info regarding what you need to set on your end to work with their equipment
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks you.
Raj
135
