10-09-2013 06:14 AM - edited 03-16-2019 07:47 PM
Dear All,
please help me on solving the below problem
E1 port on 2921 MGCP Gateway displays amber weither it's plugged or not. It is a new configuration
"show isdn status" shows Layer 1 status is SHUTDOWN
Solved! Go to Solution.
10-09-2013 07:57 PM
Hi Kennedy,
Do not confuse with colours.
Kepping RJ-45 Jack towards Earth, from left towards right see 1, 2, 4 and 5 .
You can use unterminated cable at router end.
regds,
aman
10-09-2013 06:18 AM
Hi Kennedy,
can u share the show version , show diag and show license feature from the router?
show controllers e1 output from router and show isdn status
regds,
aman
10-09-2013 07:25 AM
thanks for yor reply
moencovg#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 03:42 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
moencovg uptime is 1 hour, 1 minute
System returned to ROM by reload at 12:28:05 UTC Wed Oct 9 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2921/K9 (revision 1.0) with 897024K/45056K bytes of memory.
Processor board ID FCZ172560ED
3 Gigabit Ethernet interfaces
20 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
8 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9 FCZ172560ED
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
moencovg#show license
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
License Count: 0/0 (In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
Index 11 Feature: WAAS_Express
Index 12 Feature: UCVideo
moencovg#sh isdn status
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 32
Total Allocated ISDN CCBs = 0
moencovg#sh controllers e1
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (844 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 844 Unavail Secs
Total Data (last 5 15 minute intervals):
5 Line Code Violations, 8 Path Code Violations,
23 Slip Secs, 0 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
24 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 4201 Unavail Secs
C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 16 ports
Port adapter is analyzed
Port adapter insertion time 01:06:07 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC17147YQT
Hardware Revision : 1.0
Part Number : 73-11835-11
Top Assy. Part Number : 800-30794-07
Board Revision : A0
Deviation Number : 130603
Fab Version : 03
Product (FRU) Number : CISCO2921/K9
Version Identifier : V08
CLEI Code : CMMHS10ARB
Processor type : C2
Chassis Serial Number : FCZ172560ED
Chassis MAC Address : bc16.65e6.8b20
MAC Address block size : 80
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 37 31 34 37 59 51 54 40
0x10: 06 16 41 01 00 82 49 2E 3B 0B C0 46 03 20 00 78
0x20: 4A 07 42 41 30 88 00 01 FE 2B 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 38 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 53 31 30 41 52
0x50: 42 09 C2 C2 8B 46 43 5A 31 37 32 35 36 30 45 44
0x60: C3 06 BC 16 65 E6 8B 20 43 00 50 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number : 341-0226-03
Deviation Number : 0
PCB Serial Number : QCS1710H1CB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V03
Product (FRU) Number : PWR-2921-51-AC
CLEI Code : 0000000000
Board Revision : A0
0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
0x10: 00 C1 8B 51 43 53 31 37 31 30 48 31 43 42 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
Redundant Power Supply Adapter information
PCB Serial Number : FOC17191VSV
Part Number : 73-12224-03
Top Assy. Part Number : 800-31691-01
Board Revision : E0
Deviation Number : 135137
Fab Version : 03
Product (FRU) Number : RPS-ADPTR-2921-51
Version Identifier : V01
CLEI Code : COPQAA2JAA
0x00: 04 FF C1 8B 46 4F 43 31 37 31 39 31 56 53 56 40
0x10: 06 1A 41 01 00 82 49 2F C0 03 C0 46 03 20 00 7B
0x20: CB 01 42 45 30 88 00 02 0F E1 02 03 CB 91 52 50
0x30: 53 2D 41 44 50 54 52 2D 32 39 32 31 2D 35 31 89
0x40: 56 30 31 20 C6 8A 43 4F 50 51 41 41 32 4A 41 41
0x50: C4 08 00 00 00 00 00 00 00 00 FF FF FF FF FF FF
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Part Number : 73-11577-03
Board Revision : D0
Fab Version : 03
PCB Serial Number : FOC17121MUM
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM3-32
0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 44 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 37 31 32
0x20: 31 4D 55 4D 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Top Assy. Part Number : 800-34657-01
Part Number : 73-13419-01
Board Revision : B0
Fab Version : 05
PCB Serial Number : FOC17224W9T
Product (FRU) Number : VWIC3-1MFT-T1/E1
CLEI Code : COUIA7PCAA
RMA History : 00
0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
0x10: 82 49 34 6B 01 42 42 30 88 00 00 00 00 02 05 C1
0x20: 8B 46 4F 43 31 37 32 32 34 57 39 54 89 56 30 31
0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
WIC Slot 1:
3rd generation - FXS DID Voice daughter card (4 port)
Top Assy. Part Number : 800-33583-01
Board Revision : E0
Fab Version : 07
PCB Serial Number : FOC171787U4
RMA History : 00
Product (FRU) Number : VIC3-4FXS/DID
CLEI Code : IPUIA6JRAC
Longitudinal Calibration : 01 10 10 63 6B 10 10 9B
B7 10 10 96 6D 10 10 92
AE
0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
0x10: 42 45 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
0x20: 37 31 37 38 37 55 34 03 00 81 00 00 00 00 04 00
0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
0x50: 4A 52 41 43 D3 11 01 10 10 63 6B 10 10 9B B7 10
0x60: 10 96 6D 10 10 92 AE FF FF FF FF FF FF FF FF FF
WIC Slot 2:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-33585-01
Board Revision : E0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC1704725W
RMA History : 00
Product (FRU) Number : VIC2-4FXO
Version Identifier : V04
CLEI Code : CNUIAXJAAC
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 37 30 34 37 32 35 57 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
WIC Slot 3:
Board Revision : E0
Fab Version : 04
PCB Serial Number : FOC17036LHL
RMA History : 00
0x20: 37 30 33 36 4C 48 4C 03 00 81 00 00 00 00 04 00
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
#######################3
best regards
Kennedy
10-09-2013 07:37 AM
now I've connected the service provider E1 cable and on cucm E1 port displays "Rejected" in addition to that on the gate way the show isdn status command shows Layer 1 Deactivated
10-09-2013 07:39 AM
Hi Kennedy,
Is your E1 UP? Have u configured MGCP or H.323.?
Can u try physically shorting the pairs 1 with 4 and 2 with 5 ? just to check whether E1 port is perferect or not.
regds,
aman
10-09-2013 07:50 AM
I've configured my E1 for MGCP,
My E1 is down but when i did i loopback diag it goes up
my connection to the the SP modem is, i just use a fabricated straight through patch cord by bcuting white green, green, white orange and orange. the connect white green with orange, green with white orange and vice versa
10-09-2013 07:58 AM
Try changing the framing crc-4 to no-crc4.
if it still does not come UP, try swapping the pairs.
regds,
aman
10-09-2013 08:21 AM
Dear Aman,
nothing changed but when i reload the router i saw the below error lines
call manager backhaul registration failed
unable to setup isdn layer 3 protocol on interface
one thing that make confuse is the the E1 port dispays Amber without pluging any cable. can you tell me what the reason is ?
best regards
Kennedy
10-09-2013 08:55 AM
Hi Kennedy,
can u share the router config?
regds,
aman
10-09-2013 09:20 AM
Dear Aman,
please see the router config below
moencovg#sh run
Building configuration...
Current configuration : 7517 bytes
! Last configuration change at 16:05:28 UTC Wed Oct 9 2013 by admin
version 15.2
hostname moencovg
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 4 c5LFTnp3A5C3Ds2sCA3PU0Csl6Q1V1MpHyKNktEi5tI
no aaa new-model
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.10.10.1
ip domain name moenco.corp
ip name-server 172.20.0.23
no ipv6 cef
isdn switch-type primary-4ess
crypto pki trustpoint TP-self-signed-3990007969
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3990007969
revocation-check none
rsakeypair TP-self-signed-3990007969
crypto pki certificate chain TP-self-signed-3990007969
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393930 30303739 3639301E 170D3133 30363139 30373030
30385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39393030
30373936 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E6F7 448AA926 A7D8AAD8 D3488CFF F2928A99 E7A427F1 6EFEC5F6 0706E9B8
505657CE 98499BD6 9D7D21AF 55718077 077128E1 21C8DFD4 CD1E9F79 D161DEBC
D107795F BDB1E908 582C3140 A4F1FBC2 00C75850 28A3309F 84F229D0 95BD7ADE
121CF969 275BF813 048504D4 9D12A4B7 2A724A78 CF02A15F 29927BC8 39F5482C
F8130203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14B41221 0B2A24EC A4EB7BC8 74DD5344 87E4A0BF BD301D06
03551D0E 04160414 B412210B 2A24ECA4 EB7BC874 DD534487 E4A0BFBD 300D0609
2A864886 F70D0101 05050003 81810072 33910E76 9A03BBBF FDCFD9F5 C384A55B
D6D7E295 03AD17F8 4F7AF038 5A694E57 8A8858C4 61F10181 28C7CD37 FDAD2D1C
56CAD1D6 31AAE479 773A5807 61C136D4 EE6646A9 D7153DE9 DADB4414 68DAC5D9
3DDA1AED 6712F942 4000B818 D7424520 CBBCF430 1748A277 C1AB92C3 08905875
430F1134 6C192164 81BD656D 398B82
quit
voice-card 0
license udi pid CISCO2921/K9 sn FCZ172560ED
hw-module pvdm 0/0
username admin privilege 15 password 0 p@ssw0rd
redundancy
controller E1 0/0/0
pri-group timeslots 1-20 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.20.0.49 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 172.20.0.11
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
timing hookflash-out 50
timing guard-out 1000
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.20.0.41
ccm-manager config
mgcp
mgcp call-agent 172.20.0.41 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
gatekeeper
shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username
Replace
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username
no username cisco
Replace
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password p@ssw0rd
login
transport input telnet ssh
line vty 5 10
access-class 23 in
privilege level 15
password p@ssw0rd
login local
line vty 11 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
best regards
Kennedy
10-09-2013 09:25 AM
Dear Aman,
FYI: when i restart the cucm i can see the E1 is registered to the cucm but i make refresh to the cucm interface it immediately changed to unregistered.
best regards
Kennedy
10-09-2013 09:47 AM
Try entering the below command and save it.then, check.
regds,
aman
10-09-2013 09:30 AM
Can u try removing the command isdn bind-l3 ccm-manager under serial interface and check?
use shut and no shut?
if possible , share ccm-manager from router.
regds,
aman
10-09-2013 10:02 AM
Dear Aman,
Ive removed the command isdn bind-l3 ccm-manager under serial interface but nothing changed.
please see below the ccm-manager config
moencovg#sh ccm-manager
MGCP Domain Name: moencovg.moenco.corp
Priority Status Host
Primary Registered 172.20.0.41
First Backup None
Second Backup None
Current active Call Manager: 172.20.0.41
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 16:54:32 UTC Oct 9 2013 (elapsed time: 00:00:40)
Last MGCP traffic time: 16:55:03 UTC Oct 9 2013 (elapsed time: 00:00:10)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 172.20.0.41
Current Link State: OPEN
Statistics:
Packets recvd: 2
Recv failures: 0
Packets xmitted: 3
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1381311358-03020a20-33de-41c4-bfd5-8959b09b0e45
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
moencovg#
now it's 8 PM i'm leaving the project site but i can get you back after 30 minutes fro home
best regards
Kennedy
10-09-2013 10:12 AM
Hi Kennedy,
Save the config and just reload the router ?
regds,
aman
