MGCP E1 Port displays Amber
Dear All,
please help me on solving the below problem
E1 port on 2921 MGCP Gateway displays amber weither it's plugged or not. It is a new configuration
"show isdn status" shows Layer 1 status is SHUTDOWN
1 ACCEPTED SOLUTION
VIP Purple
Hi Kennedy,
Do not confuse with colours.
Kepping RJ-45 Jack towards Earth, from left towards right see 1, 2, 4 and 5 .
You can use unterminated cable at router end.
regds,
aman
VIP Purple
Hi Kennedy,
can u share the show version , show diag and show license feature from the router?
show controllers e1 output from router and show isdn status
regds,
aman
thanks for yor reply
moencovg#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 03:42 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
moencovg uptime is 1 hour, 1 minute
System returned to ROM by reload at 12:28:05 UTC Wed Oct 9 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 897024K/45056K bytes of memory.
Processor board ID FCZ172560ED
3 Gigabit Ethernet interfaces
20 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
8 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FCZ172560ED
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
moencovg#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
Index 11 Feature: WAAS_Express
Index 12 Feature: UCVideo
moencovg#sh isdn status
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 32
    Total Allocated ISDN CCBs = 0
moencovg#sh controllers e1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (844 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 844 Unavail Secs
  Total Data (last 5 15 minute intervals):
     5 Line Code Violations, 8 Path Code Violations,
     23 Slip Secs, 0 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
     24 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 4201 Unavail Secs
C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 16 ports
        Port adapter is analyzed
        Port adapter insertion time 01:06:07 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC17147YQT
        Hardware Revision        : 1.0
        Part Number              : 73-11835-11
        Top Assy. Part Number    : 800-30794-07
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V08
        CLEI Code                : CMMHS10ARB
        Processor type           : C2
        Chassis Serial Number    : FCZ172560ED
        Chassis MAC Address      : bc16.65e6.8b20
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 37 31 34 37 59 51 54 40
          0x10: 06 16 41 01 00 82 49 2E 3B 0B C0 46 03 20 00 78
          0x20: 4A 07 42 41 30 88 00 01 FE 2B 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 38 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 53 31 30 41 52
          0x50: 42 09 C2 C2 8B 46 43 5A 31 37 32 35 36 30 45 44
          0x60: C3 06 BC 16 65 E6 8B 20 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-03
        Deviation Number         : 0
        PCB Serial Number        : QCS1710H1CB
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V03
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 37 31 30 48 31 43 42 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
          0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
          0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
          0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
          0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
          0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
        Redundant Power Supply Adapter information
        PCB Serial Number        : FOC17191VSV
        Part Number              : 73-12224-03
        Top Assy. Part Number    : 800-31691-01
        Board Revision           : E0
        Deviation Number         : 135137
        Fab Version              : 03
        Product (FRU) Number     : RPS-ADPTR-2921-51
        Version Identifier       : V01
        CLEI Code                : COPQAA2JAA
          0x00: 04 FF C1 8B 46 4F 43 31 37 31 39 31 56 53 56 40
          0x10: 06 1A 41 01 00 82 49 2F C0 03 C0 46 03 20 00 7B
          0x20: CB 01 42 45 30 88 00 02 0F E1 02 03 CB 91 52 50
          0x30: 53 2D 41 44 50 54 52 2D 32 39 32 31 2D 35 31 89
          0x40: 56 30 31 20 C6 8A 43 4F 50 51 41 41 32 4A 41 41
          0x50: C4 08 00 00 00 00 00 00 00 00 FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11577-03
        Board Revision           : D0
        Fab Version              : 03
        PCB Serial Number        : FOC17121MUM
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 44 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 37 31 32
          0x20: 31 4D 55 4D 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
        Top Assy. Part Number    : 800-34657-01
        Part Number              : 73-13419-01
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC17224W9T
        Product (FRU) Number     : VWIC3-1MFT-T1/E1
        CLEI Code                : COUIA7PCAA
        RMA History              : 00
          0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
          0x10: 82 49 34 6B 01 42 42 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 37 32 32 34 57 39 54 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
        WIC Slot 1:
        3rd generation - FXS DID Voice daughter card (4 port)
        Top Assy. Part Number    : 800-33583-01
        Board Revision           : E0
        Fab Version              : 07
        PCB Serial Number        : FOC171787U4
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        CLEI Code                : IPUIA6JRAC
        Longitudinal Calibration : 01 10 10 63 6B 10 10 9B
                                   B7 10 10 96 6D 10 10 92
                                   AE
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
          0x10: 42 45 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 37 31 37 38 37 55 34 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
          0x50: 4A 52 41 43 D3 11 01 10 10 63 6B 10 10 9B B7 10
          0x60: 10 96 6D 10 10 92 AE FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-33585-01
        Board Revision           : E0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC1704725W
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        Version Identifier       : V04
        CLEI Code                : CNUIAXJAAC
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 37 30 34 37 32 35 57 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
        WIC Slot 3:
        Board Revision           : E0
        Fab Version              : 04
        PCB Serial Number        : FOC17036LHL
        RMA History              : 00
          0x20: 37 30 33 36 4C 48 4C 03 00 81 00 00 00 00 04 00
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
#######################3
best regards
Kennedy
now I've connected the service provider E1 cable and on cucm E1 port displays "Rejected" in addition to that on the gate way the show isdn status command shows Layer 1 Deactivated
VIP Purple
Hi Kennedy,
Is your E1 UP? Have u configured MGCP or H.323.?
Can u try physically shorting the pairs 1 with 4 and 2 with 5 ? just to check whether E1 port is perferect or not.
regds,
aman
I've configured my E1 for MGCP,
My E1 is down but when i did i loopback diag it goes up
my connection to the the SP modem is, i just use a fabricated straight through patch cord by bcuting white green, green, white orange and orange. the connect white green with orange, green with white orange and vice versa
VIP Purple
Try changing the framing crc-4 to no-crc4.
if it still does not come UP, try swapping the pairs.
regds,
aman
Dear Aman,
nothing changed but when i reload the router i saw the below error lines
call manager backhaul registration failed
unable to setup isdn layer 3 protocol on interface
one thing that make confuse is the the E1 port dispays Amber without pluging any cable. can you tell me what the reason is ?
best regards
Kennedy
VIP Purple
Hi Kennedy,
can u share the router config?
regds,
aman
Dear Aman,
please see the router config below
moencovg#sh run
Building configuration...
Current configuration : 7517 bytes
! Last configuration change at 16:05:28 UTC Wed Oct 9 2013 by admin
version 15.2
hostname moencovg
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 4 c5LFTnp3A5C3Ds2sCA3PU0Csl6Q1V1MpHyKNktEi5tI
no aaa new-model
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.10.10.1
ip domain name moenco.corp
ip name-server 172.20.0.23
no ipv6 cef
isdn switch-type primary-4ess
crypto pki trustpoint TP-self-signed-3990007969
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3990007969
revocation-check none
rsakeypair TP-self-signed-3990007969
crypto pki certificate chain TP-self-signed-3990007969
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393930 30303739 3639301E 170D3133 30363139 30373030
  30385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39393030
  30373936 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E6F7 448AA926 A7D8AAD8 D3488CFF F2928A99 E7A427F1 6EFEC5F6 0706E9B8
  505657CE 98499BD6 9D7D21AF 55718077 077128E1 21C8DFD4 CD1E9F79 D161DEBC
  D107795F BDB1E908 582C3140 A4F1FBC2 00C75850 28A3309F 84F229D0 95BD7ADE
  121CF969 275BF813 048504D4 9D12A4B7 2A724A78 CF02A15F 29927BC8 39F5482C
  F8130203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B41221 0B2A24EC A4EB7BC8 74DD5344 87E4A0BF BD301D06
  03551D0E 04160414 B412210B 2A24ECA4 EB7BC874 DD534487 E4A0BFBD 300D0609
  2A864886 F70D0101 05050003 81810072 33910E76 9A03BBBF FDCFD9F5 C384A55B
  D6D7E295 03AD17F8 4F7AF038 5A694E57 8A8858C4 61F10181 28C7CD37 FDAD2D1C
  56CAD1D6 31AAE479 773A5807 61C136D4 EE6646A9 D7153DE9 DADB4414 68DAC5D9
  3DDA1AED 6712F942 4000B818 D7424520 CBBCF430 1748A277 C1AB92C3 08905875
  430F1134 6C192164 81BD656D 398B82
        quit
voice-card 0
license udi pid CISCO2921/K9 sn FCZ172560ED
hw-module pvdm 0/0
username admin privilege 15 password 0 p@ssw0rd
redundancy
controller E1 0/0/0
pri-group timeslots 1-20 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.20.0.49 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 172.20.0.11
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
timing hookflash-out 50
timing guard-out 1000
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.20.0.41
ccm-manager config
mgcp
mgcp call-agent 172.20.0.41 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
gatekeeper
shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password p@ssw0rd
login
transport input telnet ssh
line vty 5 10
access-class 23 in
privilege level 15
password p@ssw0rd
login local
line vty 11 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
best regards
Kennedy
Dear Aman,
FYI: when i restart the cucm i can see the E1 is registered to the cucm but i make refresh to the cucm interface it immediately changed to unregistered.
best regards
Kennedy
VIP Purple
Try entering the below command and save it.then, check.
regds,
aman
VIP Purple
Can u try removing the command isdn bind-l3 ccm-manager under serial interface and check?
use shut and no shut?
if possible , share ccm-manager from router.
regds,
aman
Dear Aman,
Ive removed the command isdn bind-l3 ccm-manager under serial interface but nothing changed.
please see below the ccm-manager config
moencovg#sh ccm-manager
MGCP Domain Name: moencovg.moenco.corp
Priority        Status                   Host
Primary         Registered               172.20.0.41
First Backup    None
Second Backup   None
Current active Call Manager:    172.20.0.41
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            16:54:32 UTC Oct 9 2013 (elapsed time: 00:00:40)
Last MGCP traffic time:         16:55:03 UTC Oct 9 2013 (elapsed time: 00:00:10)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  172.20.0.41
    Current Link State: OPEN
    Statistics:
        Packets recvd:   2
        Recv failures:   0
        Packets xmitted: 3
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1381311358-03020a20-33de-41c4-bfd5-8959b09b0e45
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 1
          Download Failed              : 0
          TFTP Download Failed         : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
moencovg#
now it's 8 PM i'm leaving the project site but i can get you back after 30 minutes fro home
best regards
Kennedy
VIP Purple
Hi Kennedy,
Save the config and just reload the router ?
regds,
aman
Dear Aman,
I've saved the config and did a reload
1- on gateway
no ccm-manager config server 172.20.0.41
no ccm-manager config      /you have to edit setting on your config on your CUCM , so better not use these commands?
mgcp
mgcp dtmf-relay voip codec all mode out-of -band
mgcp bind control sourec-interface ( G0/0) interface which can be reachble to your CUCM
mgcp bind medial sourec-interface ( G0/0) interface which can be reachble to your CUCM
2- on the CUCM the name of your router should be as the below:-
this the same name of your router.
Thank you
please rate all useful information
Re:MGCP E1 Port displays Amber
Please find the below link for the problem for your Layer 1 which is shown deactivated.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b76.shtml
Thank you
that was just for few seconds it turned back to SHUTDOWN
best regards
kennedy
VIP Super Bronze
You need to check your cabling. Your e1 controller has alarms on it. I suggest you sort that out first.
Second ensure that your mgcp domain configured on cucm is the same as the mgcp domain name that you see when you do a show ccm-manager
Sent from Cisco Technical Support Android App
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
the e1 is displaying amber without any cable being pluged & that's why I'm confused. can you tell me what the reason is ?
best regards
Kennedy
VIP Super Bronze
The e1 will display amber without any active circuit connection. This is normal. When you plug a cable to your e1 and you have an active connection to your telco, then the light changes from amber to green. If you plug a cable in and the light still shows as amber, then there is a problem either with the cable, your card , framing configuraion or your telco has not activated your line..
Dont waste your time reloading and re-configuring..You need to focus on bringing up your layer 1...which invlolves cabling, framing configuration etc
"opportunity is a haughty goddess who waste no time with those who are unprepared"
+5 for MR.Aokanlawon , please check your cable . When you get on layer 1 activated , so we can easily troubleshoot all configuration for mgcp if you will fix any other problem.
Thank you
after plugging the telco cable and restarting the cucm i can see the E1 is registered to the cucm  but when i make refresh to the cucm interface it immediately changed to  unregistered. why is that ?
best regards
Kennedy
VIP Super Bronze
Please send the ff:
sh isdn status
show ccm-manager
My local time 4:50 PM & I'm not @ the project site but i've taken some of the configurations. there are also other configurations those i've uploaded in this forum earlier.
    Layer 1 Status:
        DEACTIVATED #currently it is shutdown#
    Layer 2 Status:
    Layer 3 Status:
First Backup    None
Second Backup   None
Backhaul Link info:
    Link Protocol:      TCP
    Statistics:
        Packets recvd:   2
        Recv failures:   0
        Packets xmitted: 3
        Xmit failures:   0
          Download Failed              : 0
FAX mode: disable
moencovg#
Best Regards
Kennedy
VIP Super Bronze
When you get back to site..please send the output that I asked for..
Why is your e1 in a shut down state..try and enable it..
conf t
controller e1 0/0/0
no shut
I've tried to do that many times but it couldn't came up and for how long hours are you available from now on ?
best regards
Kennedy
VIP Super Bronze
Do you have another e1 card? If you I suggest you swap this one out and put that in..Do you also know if this line has been actuvated by your telco?
I am available for the next 11/2 hrs
i don't have another e1 card and the telco already activated the line.
FYI when i did a loopback diag my controller e1 gets up why is that ?
is there any specific framing that i should configure ?
best regards
Kennedy
900
