MGCP E1 PRI CM 6.1
Hi Guys,
I have CM 6.1 connected to a gateway with MGCP enabled.
The problem is that the E1 port is not registering. I looped back the E1 using a physical connector.
the show mgcp is up, the show ccm-manager is registered and the show mgcp endpoints are showing.
1 ACCEPTED SOLUTION
Re: MGCP E1 PRI CM 6.1
Certainly is self explanatory, the question why are the controllers showing as 1/0 and 1/1?
When you specified the card type did you reload gateway as this is recommended.
Also whilst validating the IOS the The current IOS certainly support the NM-HDV2, the software advisor also indicates that the VWIC2 is not supported?
There were no open caveats which I could identify in relation to the symptoms that you are seeing.
Can you possibly try configuring one of the slots in CUCM with a VWIC-2MFT-E1 instead of VWIC2? Does endpoint identifier change to 1/0?
Rgds
Allan.
Three aspects which you can initially check:-
First verify that the pri-group under the controller is configured with service mgcp, and secondly verify that the command 'isdn bind-l3 ccm-manager is under the Serial interface.
The commands should have been automically configured when you entered ccm-manager config.
If the later is not the case run 'no ccm-manager config' and then add it back, does this resolve the issue?
Please can you confirm the hostname of your gateway, and also whether you have additionally specified a ip domain-name ???.
For example if your gateway hostname is VG1 and ip domain-name is domain.com, then your MGCP domain name should be VG1.domain.com and this should be the name you have configured for your MGCP endpoint in CCM.
If you have configured an IP address, then ensure that CCM is able to resolve VG1.domain.com.
If this still fail to resolve your issue trying re-initialising mgcp by removeing it and then re-applying 'no mgcp' then 'mgcp'
After the above, please can you post the outout from a show ccm-manager.
HTH.
Rgds
Allan.
Hi Allan,
I tried what you mentioned above.
I saw the port registered for but i refreshed again it unregistered again.
Here is the show ccm-manager: the Pub is the 11, Sub 12
(Thanks in advance.)
MGCP Domain Name: VG-Vivacell-CM
Priority Status Host
Primary Registered X.X.X.12
First Backup Backup Ready X.X.X.11
Second Backup None
Current active Call Manager: X.X.X.12
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 11:52:54 UTC Oct 13 2008 (elapsed time: 00:00:27)
Last MGCP traffic time: 11:53:07 UTC Oct 13 2008 (elapsed time: 00:00:14)
Last failover time: 11:44:57 UTC Oct 13 2008 from (X.X.X.12)
Last switchback time: 11:45:42 UTC Oct 13 2008 from (X.X.X.11)
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: X.X.X.12
Current Link State: OPEN
Statistics:
Packets recvd: 2
Recv failures: 0
Packets xmitted: 2
Xmit failures: 0
PRI Ports being backhauled:
Slot 1, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 2
Download Successful : 2
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 1
Last config download command:
Configuration Error History:
controller E1 1/0/0
no shut
controller E1 1/0/0
linecode hdb3
controller E1 1/0/0
no pri-group timeslots 1-31
controller E1 1/0/0
shut
FAX mode: cisco
Verify IP connectivity from your gateway to both Primary and Backup CallManager, the output from show ccm-manager suggests that the endpoint was unable to communicate with the Primary.
The gateway un-registering can be attributed to a number of reasons, and depends on how you have deployed the MGCP gateway. For example, is the MGCP gateway within a remote branch providing local PSTN breakout or is it within central office? Thus QoS will be a pre-requisite in order to guarantee Signalling?
I have noticed that there is a failed configuration, this could be due to an incorrect source-address being used on the gateway for TFTP.
Can you post the configuration of the gateway.
Allan.
Hi ,
They are in the same site and the same VLAN and subnet. Connectivity is good.
Here is the show mgcp stat, there are a lot of failed attempts here in the AuditEndpoint :
RTR#show mgcp statistics
UDP pkts rx 2122, tx 2161
Unrecognized rx pkts 0, MGCP message parsing errors 0
Duplicate MGCP ack tx 0, Invalid versions count 0
CreateConn rx 0, successful 0, failed 0
DeleteConn rx 0, successful 0, failed 0
ModifyConn rx 0, successful 0, failed 0
DeleteConn tx 0, successful 0, failed 0
NotifyRequest rx 0, successful 0, failed 0
AuditConnection rx 0, successful 0, failed 0
AuditEndpoint rx 753, successful 0, failed 753
RestartInProgress tx 30, successful 30, failed 0
Notify tx 1342, successful 1342, failed 0
ACK tx 0, NACK tx 753
ACK rx 1367, NACK rx 2
IP address based Call Agents statistics:
IP address X.X.X.11, Total msg rx 70,
successful 7, failed 63
IP address X.X.X.12, Total msg rx 863,
successful 772, failed 91
System resource check is DISABLED. No available statistic
DS0 Resource Statistics
Utilization: 0.00 percent
Total channels: 60
Addressable channels: 0
Inuse channels: 0
Disabled channels: 60
Free channels: 0
Can you provide the configuration? I would like to establish what configuration has been auto-generated or downloaded specifically under the controller(s)
I noticed from the output that there are 60 disabled channels? If you run a 'show voice port summary' does show the number of ports you would expect?
If there are insufficient timeslot configured, or there is none at all, there there no DSPs available.
Allan.
Hi Allan,
Here is the output of the port summary and the config (i.e.: the voice port for the first E1 is being shut by itself)
version 12.4
hostname VG-Vivacell-CM
boot-start-marker
boot-end-marker
card type e1 1 1
card type e1 2 1
no aaa new-model
network-clock-participate slot 1
network-clock-participate slot 2
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice-card 2
no dspfarm
--More-- !
controller E1 1/0
pri-group timeslots 1-31 service mgcp
controller E1 1/1
controller E1 2/0
controller E1 2/1
interface GigabitEthernet0/0
ip address X.X.X.10 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 X.X.X.254
ip http server
no ip http secure-server
--More-- !
control-plane
voice-port 1/0:15
shutdown
voice-port 1/1:15
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.11
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server X.X.X.12
ccm-manager config
mgcp
mgcp call-agent X.X.X.12 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 9 pots
service mgcp
direct-inward-dial
port 1/0:15
dial-peer voice 10 pots
service mgcp
direct-inward-dial
port 1/1:15
--More-- line con 0
password cisco
login
line aux 0
password cisco
login
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Hi Allan,
Please find attached the port summary and the config (i.e.: the voice port for the first E1 is being shut by itself)
Firstly can you verify that the endpoint device name in CUCM is exactly 'VG-Vivacell-CM' with no domain suffix.
Also remove both your post dial-peers 9 and 10, these are not required as the serial interface is already bound to CallManager with 'isdn bind-l3 ccm-manager'.
Which incidentally I noticed is missing from Serial1/1:15, this command is auto-generated by ccm-manager config, exactly how it appear of serial1/0:15.
Also is it possible to fix the speed and duplex on the gigabit interface? Are there errors on the port?
Once you have made the changes can initiate a 'no ccm-manager config' and then 'ccm-manager config'. Then restart MGCP, 'no mgcp' and then 'mgcp' as before.
Allan.
Hi Allan,
I did that but no luck.
The "'isdn bind-l3 ccm-manager" was no generated by CM, I entered it myself.
When you added the command manually on the serial interfaces does the gateway endpoint then register with CUCM?
Please post the 'show ccm-manager'.
Can also capture the following debug 'debug ccm conf eve'. Remove the 'ccm-manager config' command and then enable the debug. After the debug is enable re-apply the the 'ccm-manager config' command.
The debug should provide a clearer picture as to what is happening when the config is downloaded.
Allan.
Hi Allan,
Please find attached the debug.
Hi Allan,
It would appear from the debug that the issue is that CUCM is try to configure the incorrect controller?
According to the running-config both your E1 controller are in 1/0 and 2/0, whereas CUCM is attempting to configure 1/0/0 and 2/0/0?
Can provide a 'show inv', I assume you are using dual VIC2-MFTE1 modules? Either way, have you correctly specified the modules for the Gateway endpoints in CUCM?
Can you also post screen shot of the gateway config detailing the module configuration.
Allan.
The E1 are built in to the NM-HDV2 2T1/E1 module. The E1 card type do not show in the show diag command.
Can you advise what CUCM version you are running, the 'sh ver' from the gateway, and if possible capture the screen shot of the gateway device again, so that is displays the top of screen and the slots?
Allan.
Further to my previous post, this information will assist in whether you are running into an IOS or CUCM compatibility issue. Which is what it would appear as CUCM is trying to configure a slot that does not exist.
Also for your information the NM-HDV2 when the configured for E1 it is possible that the E1 controllers may not come up properly when connected to reliable E1 circuits.
The output of the show controllers E1 command can indicate large accumulations of Line Code Violations (LCVs) and Path Code Violations (PCVs). The problem can be the result of how the E1 line has been provisioned by the Telco; specifically whether Wet Current is provided or not. On the NM-HDV2 product there are two jumper blocks which control whether the onboard T1/E1 controllers support Wet Current or not. These jumpers are identified on the Printed Circuit Board (PCB) of the Network Module as J6 and J7 (see photograph). J6 is the jumper block for onboard controller 1 while J7 is the jumper block for onboard controller 0. The pin count for each jumper block is from 1 to 3. Pin 1 is the rightmost pin and Pin 3 is the leftmost pin. When Pins 1 and 2 are short-circuited (Right Jumper Setting) the onboard controller is set for "Wet Current Mode", and when Pins 2 and 3 are short-circuited (Left Jumper Setting) the onboard controller is set for "Normal Mode". Early production NM-HDV2s shipped with the jumper blocks set to expect Wet Current to be supplied by the Telco, and this causes problems for some E1 users. When you move the setting to Normal Mode, it typically clears up the problem. Current production NM-HDV2s now ship with the jumper blocks set for Normal Mode.
Please refer to the following URL:-
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008039c333.shtml
Rgds
Allan
Hi Allan,
The version: 6.1.2.1000-13
Please find attached the requested files
Can you post the screen shot when you open the drop down option for selecting the sub-unit on the gateway configuration.
I would like to verify what module options are available for selection, and confirm that correct one is selected.
Rgds
Allan.
Hi Allan,
please find attached the screen shot you requested.
Under the card type e1 1 1 command on the gateway, do you other options after specifying card type e1 1 ?
When you specify the card type it creates the E1 controllers accordingly, and within CUCM the endpoints have been added as 1/0/0 and 1/0/1 which do not correspond to gateway configuration.
Unfortunately all the NM-HDV2 documentation and specifications do not list the VWIC2 as a supported module? I suspect that the documentation has not been updated to reflect that it does, else why would you have the option to select it.
I believe the issue is probably due to the incorrect card type being set, thus the controllers have been inappropriate set.
Rgds
Allan.
Hi Allan,
Here is the available config under the card:
VG-Vivacell-CM(config)#card type e1 ?
<0-4> Card slot number (always 0 for 1800 series & 2801 routers)
VG-Vivacell-CM(config)#card type e1 1 ?
<0-1> WIC slot number (0:WIC, 1:Onboard for NM-HDV2)
Rgds
Allan.
Well your right it turned out that i should have selected the second "subunit 1" which clearly states NM-HV2-ONBOARD-E1. After that the ports registered quickly. Thank you for all your efforts.
Can you guide me to a document that compares the MGCP "isdn bind-l3 ccm-manager" method with the other one with the dial-peers ?
I may have the same issue. I have a 3825 with 4 VWIC2-2MFT-T1/E1
The only option I get on CUCM screen for MGCP on this router is NM-4VIWC-MBRD.
So what you are saying I should be using the VWIC cards, not the VWIC2 cards? Or ?
Thanks!
Hi Tommer,
The previous problem was that the incorrect module was selected for the particular slot, the NM-HV has onboard E1 which I can only assume is a vwic not vwic2 as the documentation does not list vwic2 as a supported module.
When you select the NM-4VWIC-MBRD and then update, you should then see sub-slot drop down options, here you should be able to select the VWIC2-2MFT-T1/E1 modules.
Hope this helps.
Allan.
Pls rate helpful posts.
Just checking. That is what I have setup.
901
