MGCP E1 Register - Unregister to CCM
Hello There,
We are using CCM 5.1.2 and 2851 voice gateway with E1. E1 normally registered to CCM with MGCP. Last week E1 registered and unregistered abnormally. We restarted CCM and router but nothing changed. E1 is running with H.323 now. Configuration is like that,
isdn switch-type primary-net5
controller E1 0/3/0
pri-group timeslots 1-31 service mgcp
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager redundant-host 10.1.3.1 10.1.2.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.1.1
ccm-manager config
mgcp
mgcp call-agent 10.1.1.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/3/0:15
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.5.5.1 port 2000
max-ephones 30
max-dn 30
Why we couldn't run E1 with MGCP? Any idea?
Thanks for your help.
Anonymous
N/A
Re: MGCP E1 Register - Unregister to CCM
You may be hitting with a bug : check the details of this one : CSCeh13683
VIP Super Bronze
To resolve this, you will need to simulate the problem again.
debug mgcp packet...look at the response codes mgcp returns...something like 200, 400, 500...
stop mgcp and restart mgcp with no mgcp and mgcp with debug mgcp packet on...
capture the mgcp exchane betwen ccm and gateway.
use sh ccm-manager to see the domain name returned and check its the same as what you have configured on CCM.
Also try and ping the FQDN of the gateway from the CCM server..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
One aspect that you need to consider which concerns MGCP is which interface MGCP is using for its source address?
Typically MGCP defaults to the loopback if configured unless a different interface is specified as the source.
Your configuration does not specifically indicated an MGCP source-interface, therefore if you have multiple IP interfaces then you need to determine which address is used by MGCP. The command show ip socket should indicate port 2427 and the source address. Is this address reachable by CallManager.
I would recommend that you configure or specify a specific MGCP source-interface, this will avoid an incorrect source address being selected.
Please bear in mind that when you specify a source-interface which is not a loopback, then it highly probable that after the gateway is reloaded MGCP will be unable bind to a physical interface unless the operational status is UP.
I have also come across issues with registration unless you specify the network-clock-participate command. Ordinarily this should not be necessary, however on 12.4.9(T2) when the configuration fails to download, I configure the clock command, remove and re-apply mgcp as stated in the previous post and then registration is successful.
Allan.
I have seen this issue a few times and everytime I have seen it I have removed the 'ccm-manager config server x.x.x.x' command and it seems to be fine after that.
A bunch of other guys I work woth ahve had the same issue and done the same remove the config server and all was okay.
it seems to work for the initial install but for some reason after a while the t1 or e1's either just stop working or the config actually disappears..
Thats been my experience
584
