MGCP for T1 CAS
Can I use MGCP if i have a T1 CAS circuit termination on my gateway?
Bronze
Re: MGCP for T1 CAS
Yes absolutely you can use MGCP with T1 CAS. In the CallManager select CAS as the protocol.
Re: MGCP for T1 CAS
How would it backhaul q931 messages, there are no q931 messages on a T1-CAS.
Bronze
Re: MGCP for T1 CAS
q931 does not apply to CAS
But here is a doc with example config
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a008022eaa3.shtml
Green
Re: MGCP for T1 CAS
You are correct.
T1CAS uses other signalling we actually support E&M wink start and dealy dial.
Note that when using 6608 Blade with T1 CAS configured the signalling will be as follows:
PSTN --> T1 CAS -- 6608 --- ISDN Q931 BH Messages to CCM.
The blade will convert ISDN Q931 BH messages from|to CCM into CAS messages.
258
