04-13-2007 03:01 PM - edited 03-14-2019 08:59 PM
How do you configure MGCP to support a fractional PRI? It keeps changing the pri-group on the controller to all 24 channels.
Solved! Go to Solution.
04-20-2007 01:37 AM
Cisco DO NOT support the use of MGCP with fractional E1's. This said, there is an UNSUPPORT work around which allows you to specify in call manager which channels are available, see below: -
Within the advanced CallManager service parameters (not shown by default) there is a field called "Change B-Channel Maintenance Status 1" which can be altered to mark channels out of service. The string below will need altering depending on how many channels are in use (0 = available, 1 = unavailable). The string below is an example for 20 channels.
Change B-Channel Maintenance Status 1 as follows:
S0/DS1-0@SDA123456789ABC = 0000 0000 0000 0000 0000 0111 1111 1111
PKS
04-13-2007 03:51 PM
yes read these threads.
If using CCM-manager config, i would recommend to remove that command as Callmanager has no idea how many channels are active on the PRI. It will think that its a full PRI and change the config accordingly.
HTh
Sankar
PS: please remember to rate posts!
04-19-2007 10:16 AM
MGCP doesn't support fractional PRI's. The only way to get this to work (unsupported) is to not allow CM to download MGCP changes to the router.
The best solution might be to migrate your gateway to h323.
John
04-20-2007 01:37 AM
PKS
