09-13-2017 11:59 AM - edited 03-17-2019 11:10 AM
I have a 4331 Version 15.5(3)S4b, router with a 4 port FXO card.
The system is running MGCP. CM 10.5
Having issues with caller ID. Calls come in as unknown.
If i do a shut/no shut on the voice port, the caller ID works, ONCE.
Then all calls are back to unknown until i do another shut/no shut.
Kind of lost. Any help would be great .
voice-port 0/1/0
trunk-group PSTN
no battery-reversal
output attenuation 14
echo-cancel coverage 32
echo-cancel erl worst-case 3
timing hookflash-out 50
description xxx-xxx-xxxx
caller-id enable
09-13-2017 08:35 PM
You can get the outputs of "debug mgcp packets" and "debug vpm signal" for a good and bad call to check the difference in signaling. We need to ensure that Telco sends caller id for all calls, it can be verified via debugs.
Manish
- Do rate useful posts -
09-19-2017 12:21 PM
I am receiving caller ID from the telco as it works for the first call everytime i do a shut/no shut on the fxo port, then fails on all other calls
Sep 19 13:46:36.417 CDT: //-1/xxxxxxxxxxxx/MGCP/mgcp_send_piggyback_msg(1623):[lvl=1]SUCCESSFUL retransmission
Sep 19 13:46:36.417 CDT: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_notify_msg(3575):[lvl=1]NTFY Packet sent successfully
Sep 19 13:46:36.417 CDT: //261/B2F491C28211/MGCP|aaln/S0/SU1/0|-1|-1/<VOICE>/mgcp_is_endpt_fxo(5081):[lvl=0]voice_callp 0x7F96317D2EA0
Sep 19 13:46:36.417 CDT: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_callerid(11279):[lvl=0]CallerID: "",1234567890,"WIRELESS CALLER"
Sep 19 13:46:36.417 CDT: //-1/xxxxxxxxxxxx/MGCP/mgcp_cr_and_init_evt_node(4597):[lvl=1]$$$ the node pointer 7F96384E3A08
11-10-2017 08:37 AM
Ended up just converting it to SIP, worked perfect out of the box.
