Community Member
MGCP FXO Port registration Rejected
Guys,
I am trying to configure an MGCP FXO Port
amd each time registration is rejected what am i doing wrong. see attached.
Re: MGCP FXO Port registration Rejected
Hi!
Seems you did not enable mgcp on any dial-peer. In fact there are no dial-peers configured.
You need to bind the MGCP application to the voice port. It should look something like:
ccm-manager config
dial-peer voice 100 pots
service mgcpapp
port 0/0/0
Please refer to:
http://www.cisco.com/en/US/docs/routers/access/vgd1t3/rel1_0/software/configuration/guide/VGD_mgcp.html
I hope this helps, if it does please rate!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
To add to Teresa's good notes (+5), you could additionally be running into a domain name issue. The domain name for the gateway configuration on CallManager must be the same as on the gateway. Try either:
1. Changing the gateway name in CUCM to just ocgr22, or
2. Configuring the domain name on the MGCP gateway by entering the command "ip domain name "
Also, since the hostname of the CUCM is used in the 'mgcp call-agent' command, add the command 'ip host OCTUC01 10.34.159.43' to allow the gateway to resolve the hostname to the actual address.
Hope this helps.
Michael.
Community Member
hi Teresa, Good point .. but the GW is configured to download it's config from the CM
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold bind Loopback0
ccm-manager config server 10.34.159.43
ccm-manager config
when you issue the command show ccm-manager ...
Priority Status Host
Primary Registered OCTUC01 (10.34.159.43)
First Backup None
Second Backup None
Current active Call Manager: 10.34.159.43
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 08:16:51 bst Jul 22 2009 (elapsed time: 00:00:13)
Last MGCP traffic time: 08:16:51 bst Jul 22 2009 (elapsed time: 00:00:13)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.34.159.43
Current Link State: OPEN
Statistics:
Packets recvd: 101
Recv failures: 0
Packets xmitted: 159
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 3, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 59
Download Successful : 58
Download Failed : 0
TFTP Download Failed : 2155
Configuration Attempted : 8
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 9
Last config download command:
FAX mode: disable
Configuration Error History:
voice-port 0/1/0
echo-cancel coverage 8
end
voice-port 0/1/0
end
voice-port 0/1/0
end
voice-port 0/1/0
end
voice-port 0/1/0
end
voice-port 0/1/0
end
voice-port 0/1/0
end
voice-port 0/1/0
end
Community Member
I have exactly the same problem with the gateway 881 SRST.
I need help please !
Thanks !
Community Member
I've seen this scenario resolved by forcing the config from the VG side - OUT of config do the following:
ccm-manager config-download check reset
Community Member
I know this is an old posts
I know this is an old posts but this worked for me.
Community Member
Your TFTP downloads are FAILING. Try this:
ip tftp source-interface loopback 0
Community Member
Hi everyone,
I don't know if the issue is solved for everyone (hence no replies since 2009), but I wanted to share what I did, so that everyone can benefit from that...
On my setup, my FXO and FXS port registrations (of the 881SRST) were failing and this didn't change with CCM configuring the device or with manual device/dial-peer config.
I also did receive config. errors that are complaining about "echo-cancel coverage 8"... I overcame this error with disabling echo cancellation on ucm config.
Then, in UCM, I set the 881SRST gateway to have NM-4VWIC-MBRD on module slot 0, VIC3-4FXS/DID on subunit 1 and VIC2-1FXO on subunit 3. Then I configured dial-peers for all ports manually on the router. After this, I could successfully register the devices I created on UCM. The dial-peer config I did for each port was basically this:
service mgcpapp
port 0
description FXS PORT 0 - aaln/S0/SU1/0@
By the way, the ports you create on UCM should be Loopstart... At least it was on my physical config
Hope this helps someone.
Emre
Community Member
I have a simple question, the 881SRTS router can be register with a CUCM 7 and work has a remote gateway (SCCP,MGCP or H323) with FXO lines ?
Community Member
Haven't tried it with UCM7, but as far as the datasheet states, 7.1(5) should be fine...
"For SRST features for IP phones, refer to the SRST data sheet at:
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_data_sheets_list.html.
Cisco Unified Communications Manager support for analog and digital ports come with Releases 7.1(5), 8.5(1), and 8.6(2)"
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
By the way, I'm running one with UCM8.0(3) as an MGCP gateway right now...
Community Member
the 881 just have one FXO port right ?
Community Member
Yes, the 881SRST has 1 FXO and 4 FXS ports, along with 1 FE routed + 4 FE switch ports... (That's a lot of ports, for a small fixed router )
6297
