MGCP FXS ports requires a license in CUCM9
Hello!
I am connecting Some analoge phones to VG350 FXS ports which is  configured as a MGCP Gateway in CUCM. I beleive MGCP did not requires any license for it. Can some confirm this ? is there any Cisco doc on it ?
Thanks & Regards,
I don't have a doc confirming this but I have a VG220 running on CUCM BE6000 ver 9.0 and I did not need any aditional licenses.
The licenses is only for the users depending on what type of licensing you make use of the CUWL.
Voice CCIE #37771
Please check if this helps:
https://supportforums.cisco.com/thread/2218302
VIP Purple
hi,
u would be requiring UCL essential license.
regds,
aman
Ok, what about if we make it H323/SIP GW. How the user licenses can be tracked ?
If you make it an H323 gateway, then I dont think you would be registering any phones to the CUCM. All you need to do is to configure dial-peers to route the calls. So I dont think you would need any licenses then.
Sam
VIP Purple
Hi Sambit,
Technically u are correct but legally I think u would be requiring license.
even the ordering guide says Analog devices are supported with Essential USer license  and must be purchased through UCL.
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/finalcopy.pdf
regds,
aman
720
