mgcp fxs to remote site g729, silence heard
sdeltoro1
Any ideas why on remote sites using g729 the silence is heard. on central site g711 work fine. the ccm is 4.1 and the router is 1751-v using fxs.
Try these commands:
mgcp behavior g729-variants static-pt
mgcp behavior dynamically-change-codec-pt disable
Also, you can disable the advertising of G729 annex b in the service parameters.
hth,
nick
Thanks nicmatth, this work fine on the 2 ways.
I really appreciated that
