MGCP gateway can't make outbound calls
We have a CallManager 4.1 configured with a MGCP gateway and work fine, recently we installed a new CUCM 8.6.2 with the same MGCP gateway configuration, i changed the IP address of the Call Manager on the gateway  and run "no mgcp" and "mgcp" commands and the gateway is registred to  the new CUCM. inbound calls work fine but i can't make an outbound calls  knowing that they can reach the gateway when a run a mgcp debug.
MGCP Configuration:
controller E1 1/0
pri-group timeslots 1-31 service mgcp
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager fallback-mgcp
ccm-manager redundant-host y.y.y.y
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
What does the MGCP debug "debug mgcp packets" show when making an outbound call?
Exactly what happens when you call??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Like others mentioned, what is the symptom when you call?
++ Run DNA and make sure there is no CSS/Partition issue.
++ Collect debug isdn q931 and debug mgcp packets for one test call.
++ If possible detailed CCM logs, if in case CCM is releasing the call.
Murali
Re: MGCP gateway can't make outbound calls
I cheked, there is no problem in CSS/Partition.
Debug MGCP Packets:
Apr 24 19:24:27.635: MGCP Packet sent to 10.1.203.2:2427--->
NTFY 109093925 *@Voice-Gateway MGCP 0.1
X: 0
O:
Apr 24 19:24:27.635: MGCP Packet received from 10.1.203.2:2427--->
200 109093925
Apr 24 19:24:42.640: MGCP Packet sent to 10.1.203.2:2427--->
NTFY 109093926 *@Voice-Gateway MGCP 0.1
X: 0
O:
Apr 24 19:24:42.640: MGCP Packet received from 10.1.203.2:2427--->
200 109093926
From the logs atatched:-
++ Is this the call ?
Apr 24 19:02:00.516: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '1220'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0665195688'
Apr 24 19:02:00.552: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8002
++ If so, Telco sent Connect message, and GW sent Connect Ack.
Apr 24 19:02:01.384: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8002
        Connected Number i = 0x0080, '0665195688'
Apr 24 19:02:01.404: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0002
++ After 12 seconds, we receive Disconnect from the GW with inband information available.
Apr 24 19:02:13.524: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8002
        Cause i = 0x8190 - Normal call clearing
        Progress Ind i = 0x8188 - In-band info or appropriate now available
++ SO telco is releasing the call and playing fast busy or reorder tone. They need to tell us why?
++ And they didnt sent an Alering message, which tells me,  that  they were not able to route the call and ring the far end.
++ Check with them what is wrong in the setup message , Are they unhappy with the called/calling number plan and type ?
++ They should be able to tell us why, then if needed we can tweak the configuration in CCM.
Thank you for your reponse, I would just remember that I can call from the old CallManager with the same gateway.
External phone number mask can play a role here?
HI,
Do you  still have that setup, if so can you collect the logs there or can you compare the configuration ? If nothing available Speaking to telco folks will be quick than guessing games.
Murali
Bronze
I ran in to a similar issue when upgrading from 7.1.3 to 8.6.2. Never did find out what actually caused this but TAC's best guess was something missing in database after upgrade. The piece that stopped the call for us was "Calling Party Number i = 0x0081, '1220' " in the debug. The telco doesn't recognize the calling party and blocked the call. We had to delete the gateway and reconfigure it.
HI
OK, I'll try to do that, currently the gateway is in production and its connected to the old CallManager, I have to wait an hour or two after the exit of staff.
Thanks to all, the problem is resolved by changing Calling Party Transform Mask value in the route list.
Thank you for your support.
1736
