MGCP gateway in SRST mode, incoming calls not routing.
I have an MGCP gateway (1861) with SRST configured for WAN failure. There is BRI line connected to it and has a number 3709 3416. The extension numbers in the building are 8XXX (around 13 telephones).
in MGCP mode I have a translation pattern to translate the incmoning calls to 8XXX extensions and all works fine. during WAN failure (simulated) 1861 goes in SRST mode and 8 phones register to it randomly. during this, the incoming calls dont work. outgoing are fine. I have dial peer configured and translation rule for incoming also,
Can anyone help with the troubleshooting?
Here is SRST and dial peer confing
voice translation-rule 1
rule 1 /37093416/ /8904/
voice translation-profile SRST
translate called 1
voice-card 0
application
global
  service alternate default
dial-peer voice 1 pots
translation-profile incoming SRST
destination-pattern 0T
incoming called-number .
port 0/1/0
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.0.218 port 2000
max-ephones 8
max-dn 14 dual-line
time-format 24
Any help is appreciated
Thanks and Regards
Shruti
1 ACCEPTED SOLUTION
Re: MGCP gateway in SRST mode, incoming calls not routing.
try to modify your pots dialpeer as follows
dialpeer voice 22 pots
direct-inward-dial
and remove the profile from the call-manager-fallback. Test it out.
if this helpful, plz rate the post.
cheers
Maybe you should take good cara of the Status of Callmanager MGCP gatway  Cause MGCP will turn to Callmanager For Routing Calls.
And you can
show call-manager-fallback
confi ter
no mgcp
mgcp
to see if can be OK
You should lookup on MGCP troubleshoot fr cisco.com
Thanks for the quick reply. but the problem is in SRST mode not in MGCP.
what do you think?
thanks
direct-inward-dial
cheers
561
