MGCP Gateway Not Registered on CM
Hi, I have a 2851 MGCP Gateway with PRI QSIG connection to a PBX.
On the VG I see :
sh ccm
MGCP Domain Name: VG-Office.Pippo.it
Priority Status Host
Primary Registered 172.16.8.41
First Backup None
Second Backup None
Current active Call Manager: 172.16.8.41
Backhaul/Redundant link port: 2428
but on a CM I see : NOT REISTERED
sUGGESTIONS ????
THANKS
Bronze
Re: MGCP Gateway Not Registered on CM
hi,
first check if your domain name "VG-Office.Pippo.it " in configured in ccm is the same as configured on the router.
check if you have selected the right gateway, port, interface type.
regards
mehmet
Also check that your controller (t1 / e1?) is up and operational. I've seen a MGCP controller router not show as registered until it was plugged into an operational E1 line and the controller brought up.
220
