MGCP Gateway / On E1 qsig => Somes channels out-of-Service
I have CCM in release 4.2
On E1 qsig link between a CISCO 2851 and IP PBX ALCATEL, some ITs goes out-of service.
I only seen this status in RTMT (see in screen shoot in attach)
Do you kwon why this channel goes in out-of service status??
When I make a shut/ no shut, all channel is anew in service.
Sébastien
Hall of Fame Super Gold
Re: MGCP Gateway / On E1 qsig => Somes channels out-of-Service
Which exact IOS are you using ?
I'm in c2800nm-ipvoicek9-mz.124-9.T3.bin
Can you try either 12.4(3j), or if need 12.4T features, 12.4(9)T7.
Also please post show controllers E1.
Please found below the sh controller E1
I have the problem on this to links
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060623, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (494 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 3748 Path Code Violations,
0 Slip Secs, 2 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 3 Severely Err Secs, 25 Unavail Secs
E1 0/0/1 is up.
No alarms detected.
Data in current interval (501 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 116 Unavail Secs
E1 0/0/0 had got some errors, are you sure the PBX supplies clock on this circuit ?
We have expeted some problem yesterday at the same time.
In the new « sh controller E1 », there is no new error.
ISRROTONDE1#sh controller E1
E1 0/0/0 is up.
No alarms detected.
Data in current interval (405 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 12 Unavail Secs
E1 0/0/1 is up.
No alarms detected.
Data in current interval (409 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 60 Unavail Secs
ISRROTONDE1#
Some errors you still have:
196
