MGCP Gateway Registration Failure with CCM 5.1
Hi all,
I summarize you my problem;
When you use an MGCP gateway in Cisco CallManager 5.1, the gateway shows as registered in show ccm−manager command output, but gateway shows as unregistered in the Cisco CallManager Administration page.
This issue is emerged after one day (or more) that the registration has been done.
thanks
best regards
Michele
Chris Deren
What version of IOS are you using? can you post your confi?
Chris
Hi Chris,
Ios Version is : 12.4(11)T.
In attach the configuration file.
Michele
I see that you are using BRIs...
Please check this link, make sure in CCM tavolare_cormons is being as gateway.
Check this troubleshooting guide:
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541c9f.html#wp1125336
