MGCP Gateway registration failure
Rajesh Revuru
Level 4
Level 4
Guys:
I have mgcp gateway which shows as registered under ccm-manager,but not under call-manager. I restarted RIS data collector as suggested by one of the cisco document. No luck
I am using loop back for mgcp bind for both control/media.
However my transcoder/CFB resources are showing as registered under call manager. I am using same loopback interface to register those resources.
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
sccp ccm group 100
description Hardware Conferencing Group
bind interface Loopback0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 102 register XXX-XXX-XX
associate profile 101 register XXX-XXX-XX
Any ideas
14 Replies 14
pklos
Level 4
Level 4
Do you have configuration lines similar to these?
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.0.10
ccm-manager config
Look here for more information:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b70.shtml
regards,
PK
regards,
PK
Jaime Valencia
what are youu trying to register?
T1?
FXS?
FXO?
javalenc
if this helps, please rate
java
T1-PRI
please post the controller config, it should be something like pri-group timeslots 1-24 service mgcp
that line is the one that tells the IOS to allow CUCM to control the PRI
javalenc
java
Jaime:
Here it is, Loopback0 is reachable from CUCM because i have sccp registered successfully for CFB/XCODE
controller T1 0/0/0
framing esf
linecode b8zs
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address 011* plan unknown type unknown
isdn bind-l3 ccm-manager
no cdp enable
interface Loopback0
ip address X.X.X.X 255.255.255.255
load-interval 30
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
ccm-manager fallback-mgcp
ccm-manager redundant-host Y.Y.Y.Y
ccm-manager mgcp
ccm-manager config server Z.Z.Z.Z Y.Y.Y.Y
ccm-manager config
mgcp
mgcp call-agent A.A.A.A 2427 service-type mgcp version 0.1
mgcp sdp simple
mgcp profile default
u using the right card and slot in CUCM??
domain name using hostname + domain if configured?
javalenc
java
Jaime:
I am using VWIC2-1MFT-T1E1-T1 and here is the following output from sh-hardware
1 Channelized E1/PRI port
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
1 Subrate T3/E3 port
8 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
Yes using hostname
i meant in CUCM config
javalenc
java
Jaime:
I think i am binding Loopback0 for both H323 and MGCP, and guess thats what causing problem. I cannot change configuration until after-hours. I will try
interface Loopback0
Yeah do you have a ip domain name set?
if so in CUCM enter hostname.domainname
Chad
Chad:
So i dont have ip domain name set.
please post you entire config and a screenshot of the CUCM mgcp page.. lastly
sh ccm-manager
Thanks!
Chad
can u post a debug mgcp packets?
javalenc
java
Here it is, but this one for E1
