MGCP -gateway registration problem
After configure MGCP-gateway on CCM i see on Router next log-
After receving RESTART from Telco switch CCM send RESTART_ACK with strange channel -Channel 127
#Debug isdn q931
*Dec 5 09:00:21.995: ISDN Se0/0/0:15 Q931: RX <- RESTART pd = 8 callref = 0x0000
Channel ID i = 0xA1830102030405060708090A0B0C0D0E0F1112131415161718191A1B1C1D1E9F
Preferred, Channel 1
Restart Indicator i = 0x80
*Dec 5 09:00:22.027: ISDN Se0/0/0:15 Q931: TX -> RESTART_ACK pd = 8 callref = 0x8000
Channel ID i = 0xA9937FFF7FFF
Exclusive, Channel 127
*Dec 5 09:00:22.051: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0000
Cause i = 0x82E418 - Invalid information element contents
Call State i = 0x3D
*Dec 5 09:00:49.891: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Display i = 'R M'
Calling Party Number i = 0x0081, '1412'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '3452245'
*Dec 5 09:00:49.915: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x8001
Cause i = 0x82E328 - Information element not implemented
Call State i = 0x01
*Dec 5 09:00:49.919: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x82AC - Requested circuit/channel not available
Display i = 'REQUESTED CHANNEL NOT AVAILABLE'
When we trying to made calls we recived busy and message - REQUESTED CHANNEL NOT AVAILABLE.
where is the problem?
Re: MGCP -gateway registration problem
you have "Cause i = 0x82E418 " in your debug.
Cause 82: No route to specified network.
The ISDN exchange receives a request to route the call through an unrecognized intermediate network.
This cause indicates that the equipment receives a request to route the call through a particular transit network. However, the equipment does not recognize the network.
The equipment that sends this cause does not recognize the transit network due to one of these reasons:
The transit network does not exist.
The transit network exists, but does not serve the equipment that sends this cause.
This cause is supported on a network-dependent basis.
http://www.cisco.com/en/US/partner/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
BR
M
The Telco Provider told me that the problem at my side-because we send him
RESTART_ACK with unknown channel -
*Dec 5 15:00:08.543: ISDN Se0/1/0:15 Q931: TX -> RESTART_ACK pd = 8 callref = 0x8000
And the block all DS on their side.
Don't know the meanings of that Channel 127!
Can you explain or show me where it's possible to see?
Do a loopback test and see if your controller comes up and registers with callmanager.
Also post your gateway config.
How many channels on your PRI? It appears that the call is going out on 15 which if not available, will create this message. Check you service module timeslots to ensure they match your PSTN setup.
1521
