MGCP Gateway Unregistered
Hi Netpro again.... i have problems whit MGCP gateway
the mgcp gw config is:
hostname gwcsm02
card type e1 0 0
card type e1 0 1
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
ip domain name test.com
isdn switch-type primary-5ess
voice-card 0
dspfarm
no local-bypass
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
controller E1 0/1/0
controller E1 0/1/1
interface GigabitEthernet0/0
ip address 10.41.204.250 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 10.41.204.251
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.41.204.251
voice-port 0/0/0:15
ccm-manager redundant-host 10.41.66.5
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.41.204.249
ccm-manager config
mgcp
mgcp call-agent 10.41.204.249 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
And
gwcsm02#show ccm-manager
MGCP Domain Name: gwcsm02.test.com
Priority Status Host
Primary Registered 10.41.204.249
First Backup Backup Ready 10.41.66.5
Second Backup None
Current active Call Manager: 10.41.204.249
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:09:08 UTC Sep 7 2008 (elapsed time: 00:00:13)
Last MGCP traffic time: 00:09:08 UTC Sep 7 2008 (elapsed time: 00:00:13)
Last failover time: 00:03:08 UTC Sep 7 2008 from (10.41.204.249)
Last switchback time: 00:03:53 UTC Sep 7 2008 from (10.41.66.5)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.41.204.249
Current Link State: OPEN
Statistics:
Packets recvd: 2
Recv failures: 0
Packets xmitted: 2
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1220763521-47cc5630-9dc4-4f61-8bc4-da484f637ca3
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 2
Download Successful : 2
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
Configuration Error History:
controller E1 0/0/0
no pri-group timeslots 1-31
FAX mode: cisco
but in the CUCM 6.1 endpoint
Product Cisco MGCP E1 Port
Gateway gwcsm02.test.com
Device Protocol PRI de acceso digital
Registration Unregistered
IP Address 10.41.204.250
End-Point Name Required Field S0/SU0/DS1-0@gwcsm.test.com
I have read several papers Media Gateway Control Protocol but the truth is not that still appears as the CUCM Unregistered
fixie rider
  • IP Telephony
Hall of Fame Super Silver
Re: MGCP Gateway Unregistered
Do you have the actual circuit plugged in? It will show unregistered until it detects carrier detect.
Chris
have u issued no shutdown under
controller E1 0/0/0 ?!
the controller e1 0/0/0 is up....
if i restart the GW in the CUCM 6.1 the GW down and up the e1 channels
fixie rider
Thanks, plug the E1 loop and the CUCM register the endpoint
thanks!
fixie rider
Hi, it looks like the gateway name defined in CUCM is different to the host name of the voice gateway. Please change it and see if the MGCP gateway will register.
Chandrasen
Please try to use
no ip domain name
on the global configuration of the MGCP GW
best regards;
A.Mohammedy
3123
