11-15-2013 04:40 AM - last edited on 03-25-2019 08:26 PM by ciscomoderator
Hi Guys,
I have a voice gateway with a BRI card on slot 0/3/0 (port 0/1) and I wanted to terminate both WAN and PSNT connection to the same gateway with MGCP protocol, and as I'm new to voice over IP world can anyone suggest/recommand me a proper guide which includes the stepts and proper explanations to acheive this task.
Thank you
Suthakar
11-15-2013 05:05 AM
My recommendation would be not to bother with MGCP and use SIP instead. Much easier to troubleshoot, more reliable and preferred these days.
Chris
11-15-2013 03:10 PM
If you are very good in DATA network then its very simple to configure MGCP on it.
1) Make sure you have routing to the VOIP network to the HQ.
2) MGCP configuration can be done with in 4 steps.
4) You must configure SRST in MGCP gateway to provide minimum phone services when WAN link unavailable.
3) You have to use gateway hostname to configure MGCP gateway in CUCM along with correct CUCM group.
Many docs and videos are available in cisco and youtube. Let me know if you stuck while configuring.
-Murali
11-15-2013 07:47 PM
Hi Suthakar,
you can refer the links for MGCP/SIP configs.
http://www.wikihow.com/Add-SIP-Gateway-to-Cisco-CUCM
https://supportforums.cisco.com/docs/DOC-22421
regds,
aman
11-19-2013 10:02 PM
Hi Guys,
First of all thank your valuable feedback
I have went through with couple of documents and specs, but still i couldn't get thinks working.
Below I have included the voice component of my config, please have a look and do let me know if i miss anything in particular,
isdn switch-type basic-net3
network-clock-select 3 BRI0/3/0
network-clock-select 4 BRI0/3/1
interface BRI0/3/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
interface BRI0/3/1
no ip address
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Port-channel1.xx (internal subinterface)
mgcp bind media source-interface Port-channel1.xx ((internal subinterface)
Thank you,
Suthakar
11-19-2013 10:33 PM
Hi Suthakar,
what is the exact issue are facing?
Is BRI UP?
can u share output of show ccm-manager, show ccm-manager hosts and show isdn status from router?
regds,
aman
11-20-2013 01:47 AM
Hi Aman,
As of now, the bri is not showing the "established state" layer 1 is active and layer 2 is down.
and also in the cucm, the gateway shows as not registered.
I can provide the show command outputs tomorrow morning.
Suthakar
11-20-2013 01:55 AM
Hi Suthakar,
Layer 2 should be Mulitple Frame Established then, GW would show registered considering the config is OK.
regds,
aman
11-20-2013 02:52 AM
Hi Amen,
Acutally the layer 2 status turns to "multiple frame established" when I remove the the following command from the BRI interface configuration
"isdn bind-l3 ccm-manager service mgcp"
interface BRI0/3/0
no ip address
Otherwise, it stays inactive.
Suthakar
11-20-2013 03:05 AM
Hi Suthakar,
Does Gateway shows as Registered in Call Manager after u remove this command?
regds,
aman
11-20-2013 03:22 AM
No its not, it only brings the layer 2 status into multiple frame established
11-20-2013 03:31 AM
Hi Suthakar,
Share the output of commands along with complete router config , show version .
Also, please share MGCP GW snapshots from CUCM.
regds,
aman
11-20-2013 03:39 AM
Hi Aman,
I don't have the access to the router now, so will share the details first thing in the morning. Thanks for the assistance.
Suthakar
11-21-2013 03:30 AM
Hi Aman,
As discussed please find the attached output as follows,
#sh isdn status
Global ISDN Switchtype = basic-net3
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN BRI0/0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
ISDN BRI0/3/0 interface
dsl 12, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 12 CCBs = 0
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 13. Layer 3 output may not apply
ISDN BRI0/3/1 interface
dsl 13, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
--More-- Active dsl 13 CCBs = 0
Total Allocated ISDN CCBs = 0
#sh ccm-manager
MGCP Domain Name: xxxxx.com
Priority Status Host
Primary Registered x.x.x.x
First Backup None
Second Backup None
Current active Call Manager: x.x.x.x
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 11:10:43 AEDST Nov 21 2013 (elapsed time: 00:00:11)
Last MGCP traffic time: 11:10:43 AEDST Nov 21 2013 (elapsed time: 00:00:11)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 05:28:32 AEDST Nov 18 2013
Last MGCP Fallback end time: 11:57:01 AEDST Nov 20 2013
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: x.x.x.x
Current Link State: OPEN
Statistics:
Packets recvd: 3
Recv failures: 0
Packets xmitted: 5
Xmit failures: 0
BRI Ports being backhauled:
Slot 0, VIC 0, port 1
Slot 0, VIC 0, port 0
Slot 0, VIC 3, port 1
Configuration Auto-Download Information
Current version-id: 1384908973-2cefe363-d1ae-423b-a6ef-a85a0d4216af
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 6
Download Successful : 3
Download Failed : 1
TFTP Download Failed : 8428
Configuration Attempted : 3
Configuration Successful : 3
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
Suthakar
11-21-2013 04:44 AM
Hi Suthakar,
Have u configured correct Domain name in Call Manager under MGCP GW?
regds,
aman
