MGCP GW configuration with PLAR and DID requirements
Dear Pros,
I am trying to setup Cisco 2821 routers as MGCP GWs and need the following services on it -
1. Connection PLAR
2. DID
For first one, the port is Digital E1 and in CCM configuration its not showing attendant number field. (which is connection plar number field).
Is there any way I can configure connection plar on this MGCP GW as I want all incoming calls on this digital PRI to be forwarded to a CTI route point.
For second thing is there any special configuration required on router for direct inward dial or CCM.
My config is as below. Please advise.
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
shutdown
interface GigabitEthernet0/0
description *** Connected to DJZGSC-6506-5F-SE2 Port 6/24 ***
ip address 10.91.45.57 255.255.255.0
duplex full
speed 100
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.91.45.5
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
connection plar 7010
ccm-manager redundant-host 10.91.77.13 10.91.77.11
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.91.77.11 10.91.77.12 10.91.77.13
ccm-manager config
mgcp
mgcp call-agent 10.91.77.12 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 100 pots
service mgcpapp
port 0/0/0:15
Pratik
Re: MGCP GW configuration with PLAR and DID requirements
Pratik,
For the first scenario, create a translation pattern in CCM that matches incoming calls and translate to the DN of the route point. For DID, if your DID range corresponds to your internal extensions, you can set the significant digits on the gateway in CCM. So, if your DID range is 2223334XXX and your internal DNs are 4XXX, you could set the significant digits to 4. If this is not the case, you will need to create a translation pattern that translates the DID to the internal DN such as a pattern that translates 2223334XXX to 56XX.
Hope this helps. If so, please rate the post.
Brandon
Thanks for your reply Brandon. So you mean to say on the router I do not need to put direct-inward-dial commands ?
Also, how can I find out the DNIS coming from router as when I run debug isdn q931, I do not get any outputs ?
You do not need the direct-inward-dial command as you do with H.323. You are not seeing output for the q931 debug because this traffic is backhauled to CCM when using MGCP. I'm not aware of any way to see the called number from the gateway.
Brandon
745
