MGCP incoming Caller number
We have just migrated a customer from non cisco PBX to Callmanager 8.6, with a 2911 gateway using MGCP on ISDN PRI 30 channel link.
Calling number was displaying ok, but now we have moved the ISDN PRI line across to callmanager, we are not seeing the external caller number, it is showing as unknown. I looked at the debugs from the gateway (output below) and cannot see it arrive.  Is their a setting on Callmanager or Gateway that I need to enable ?
Aug 17 10:47:46.780: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3868
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Called Party Number i = 0xC1, '123456'
                Plan:ISDN, Type:Subscriber(local)
Aug 17 10:47:46.792: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB868
Aug 17 10:47:46.792: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xB868
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Aug 17 10:47:54.408: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x3868
        Cause i = 0x8290 - Normal call clearing
Aug 17 10:47:54.432: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xB868
Aug 17 10:47:54.452: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x3868
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: MGCP incoming Caller number
No, you need to ask telco to send calling number, and possibly pay for the service. There is nothing that you can do on your side.
I do not know and cannot answer on why calling number was there before you moved PRI to CM, but that seems very unlikely and hard to believe,
cool, many thanks,
Thank you for the nice rating and good luck!
140
