Community Member
MGCP - ISDN One way Call
Router A has a DN 1002 and is also a MGCP gateway. The MGCP gateway is configured with inbound 4 significant digits.
Router A config:
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
mgcp
mgcp call-agent 10.10.210.11 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp fax t38 ecm
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
I can call from DN 1002 to the PSTN ephone at 6178632683
ephone-dn 1 octo-line
number 911
label Emergency........911-999
description PSTN Phone
ephone-dn 3
number 6178632683 no-reg primary
label test +1-617-863-2683
However, calling DN 1002 from the PSTN by dialing '6178631002' produces a reorder tone and the ISDN error message:
Unallocated/unassigned number
Debug shows that there is a match with the dial peer :
dial-peer voice 102 pots
destination-pattern 6178631...
port 0/3/1:23 <--------connected to the PSTN router
forward-digits 10
Translation patterns are working and there is a route pattern of 617863.XXXX - PreDot
I am not sure what is wrong, any help appreciated.
Paul
PSTN#
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 911
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: Sending SETUP callref = 0x0095 callID = 0x8016 switch = primary-ni interface = Network
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0095
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '911'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '6178631002'
Plan:ISDN, Type:National
Jun 24 00:48:21.571: ISDN Se0/3/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8095
Jun 24 00:48:21.575: ISDN Se0/3/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8095
Cause i = 0x8081 - Unallocated/unassigned number
Jun 24 00:48:21.579: ISDN Se0/3/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x0095
Jun 24 00:48:21.587: ISDN Se0/3/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8095
Re: MGCP - ISDN One way Call
The call flow isn't very clear here. You've got CUCM DNs, CME DNs, MGCP PRIs, and H323 PRIs but no real clear diagram of how these are related.
What is the device that is sending the Unallocated/Unassigned number? Is this a lab or is this an actual PSTN circuit?
If it's actual PSTN try adding a 1 before the number.
-nick
Community Member
Hi Nick,
I was about to re-post this conversation.
It is a copy and paste error.
Anyway it is a lab scenario.
Router A has a phone with DN 1002 registered to CCM7 and is also a MGCP gateway. The MGCP gateway is configured with inbound 4 significant digits.
Router A config:
controller T1 0/0/0
no ip address
encapsulation hdlc
ccm-manager mgcp
mgcp
mgcp fax t38 ecm
no cdp enable
PSTN Router config:
number 911
ephone-dn 3
port 0/3/1:23 <------ back to back connection to Router A
forward-digits 10
I can call the PSTN ephone DN 6178632683 from Router A's DN 1002.
So, I presume the ISDN is working one way ,at least.
Translation patterns are working and there is also a route pattern of 617863.XXXX - PreDot
Paul
PSTN# debug isdn q931
Standard = CCITT
217
