Community Member
mgcp problem
hi
we have a pri line terminated in a 3825 gateway router which is configured with mgcp.The mgcp endpoints is also registered with the cucm 6.0.We are able to make outgoing calls to outside numbers but we are able to hear only the other end's voice and they are not able to hear our voice.
Kindly do suggest me if there is anything to be checked in the cucm/router for solving this.
regards
kumar
1 ACCEPTED SOLUTION
Green
Re: mgcp problem
Check the MGCP binding commands
and routing from MGCP GW to IP Phones.
1 REPLY
Green
Re: mgcp problem
131
