MGCP Process hung - how to kill process?
          Hi All,
I did a no MGCP on a 3725 and its been about half an hour.
When I go back and do mcgp it says
r-fwvpn02-il#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
r-fwvpn02-il(config)#mgcp
%MGCP-SHUTTING-DOWN, Cannot restart MGCP until it is finished shutting down
Is there a way to kill this process?
This is on my WAN router so I dont want to reboot the box.
Thanks All!
Re: MGCP Process hung - how to kill process?
Unfortunately, I don't believe there is a way to kill a single process using PID in IOS.  I've heard debate on one side or the other but for MGCP, SCCP, etc...when they hang, the result (even after TAC case sometimes) is that a reboot is the workaround/fix.  Schedule some downtime and reboot is your best bet from my view.
Hailey
There is no way I am aware to
There is no way I am aware to kill the process, but usually it is hanging because there are active mgcp ports off hook. If you do a sh voice port sum, look for off hook ports and go and make them admin down. I just had this happen to me, I shut down 2 ports that were off hook and mgcp shut down. Or of course, you can reload the router.
This actually worked for
This actually worked for restarting the mgcp proccess without a router reload.
Thank you.
It looks like you are running
It looks like you are running into the BUG below
https://tools.cisco.com/bugsearch/bug/CSCej32039/?reffering_site=dumpcr
Unfortunately there is not workaround that you can do to restart the MGCP stack, you will have to reload the gateway.
JB
VIP Purple
Hi JB, thanks for sharing the
Hi JB,
thanks for sharing the bug[+5]
I checked but this bug is not publicly available.
regds,
aman
Hi Aman, it looks like the
Hi Aman,
it looks like the BUG was not documented correctly, i have pasted the content for details.
Symptoms: Once the mgcp command was shut down by
configuring the no mgcp, it cannot be
restarted by the mgcp command. The router has
to be reloaded to restart the mgcp command.
Conditions: This symptom has been observed when the
mgcp command was shut down by configuring the
no mgcp command.
Workaround: There is no workaround
JB
VIP Purple
thnaks for reply. Is this any
thnaks for reply.
Is this any router IOS specific?
regds,
aman
Aman, It was first reported
Aman,
It was first reported in 12.X train, but i can see it been reported on higher versions also.
JB
VIP Purple
thanks for updates[+5] regds
regds,
aman
SDR_Lab(config)#mgcp%MGCP
In this case, you have to look for any hung ports, make them admin down and then resetting MGCP will work
SDR_Lab(config)#no mgcp
Rgds,
Shridhar Kadolkar
2072
