mgcp question
Now, I find thtre are some trouble in my IPT in running process. The PSTN call can enter into MGCP gateway(I ckeck it through debug isdn q931),but the call can't go to CCM. I find the mgcp is deactive in MGCP VG(I check it through sh mgcp in mgcp VG). After I restart MGCP in VG through no mgcp then mgcp command, the question is solved. Why ? The question comes in the running process.
Bronze
Re: mgcp question
Its possible that the MGCP keepalives were not being sent or received by the gateway and thus the gateway probably unregistered with the CM.
Check out this link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/voipt_c/vtstech/vts_mgcp.htm#wp1035765
Show mgcp stat could be a useful command for finding out if the the connection is being dropped due to missed mgcp keepalives.
Re: mgcp question
I'm not agree with mparekh. Because my MGCP VG is in remote office and the MGCP is deployed SRST. If the MGCP VG can't register with the CM, the SRST should work in and PSTN can go into remote office and remote office can't communicate with centre office.But now, the question is the PSTN can't go into remote office and the remote office can communicate with centre office. So I'm very confused.Why?
Re: mgcp question
hi,
Can u please paste the config...
Re: mgcp question
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
interface Serial0/1/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/1/0:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.48.198.5
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.48.198.6 10.48.198.5
ccm-manager config
mgcp
mgcp call-agent 10.48.198.6 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local Loopback0
sccp ccm 10.48.198.5 identifier 2 version 4.0
sccp
sccp ccm group 100
associate ccm 2 priority 2
associate profile 10 register BJ3825_CFB
associate profile 20 register BJ3825_xcode
associate profile 30 register BJ3825_MTP
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 20 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 6
associate application SCCP
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions hardware 4
dial-peer voice 2 pots
service mgcpapp
destination-pattern 7399
port 0/2/0
dial-peer voice 3 pots
service mgcpapp
port 0/2/1
dial-peer voice 4 pots
service mgcpapp
port 0/2/2
dial-peer voice 5 pots
service mgcpapp
port 0/2/3
dial-peer voice 7399 pots
destination-pattern 65637399
port 0/2/0
dial-peer voice 100 pots
destination-pattern 9T
incoming called-number 7[2-4]..
direct-inward-dial
port 0/1/0:15
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
call-manager-fallback
max-conferences 12 gain -6
ip source-address 10.48.200.1 port 2000
max-ephones 100
max-dn 200 dual-line
dialplan-pattern 1 65637388 extension-length 4 extension-pattern 6200
dialplan-pattern 2 6563.... extension-length 4
keepalive 60
voicemail 902161053650
time-format 24
Re: mgcp question
hi,
i may be incorrect but i believe the following commmand is missing :
ccm-manager switchback
To specify the time when control is to be returned to the primary Cisco CallManager server once it becomes available, use the ccm-manager switchback command in global configuration mode. To reset to the default, use the no form of this command.
ccm-manager switchback {graceful | immediate | schedule-time hh:mm | uptime-delay minutes}
Re: mgcp question
I think I need not this command.Because the default switchback is graceful.
Re: mgcp question
can u paste sh ccm-manager output
160
