MGCP SRST FXO Inbound Call Silence
I am testing SRST situations with 2901 routers, CUCM 9.1, with MGCP and H.323 fall back.There is no PRI, just Centrex lines at each location. Outbound calls work just fine. When inbound calls occur, the call connects but there is just silence. Normally all calls go to an AA. I have set up the voice-ports for connection plar to the internal non-did extension. The only DIDs in the district are the ones that forward to an AA, no DIDs are present on internal phones.
Here is the config, followed be a debug of ccapi inout
Current configuration : 7039 bytes
! Last configuration change at 02:19:08 EST Sun Jul 28 2013 by fiadmin
! NVRAM config last updated at 02:19:09 EST Sun Jul 28 2013 by fiadmin
version 15.2
hostname FHS-2901-VOICE
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
clock summer-time EST recurring
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
application
global
  service alternate default
license udi pid CISCO2901/K9 sn FTX172182HV
hw-module pvdm 0/0
username fiadmin privilege 15 secret 4 ZF5KtxAZhTFJ0JRyoATt68n2mVpH3gfrq14eGxSQY8c
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.25.1.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.25.1.1
access-list 2 permit 10.25.5.0 0.0.0.255
access-list 2 permit 10.25.15.0 0.0.0.255
access-list 2 permit 10.25.25.0 0.0.0.255
access-list 2 permit 10.25.35.0 0.0.0.255
access-list 2 permit 10.25.40.0 0.0.0.255
access-list 2 permit 172.18.20.0 0.0.0.255
control-plane
voice-port 0/0/0
timing hookflash-out 50
timing guard-out 1000
connection plar 5551014500
description 440-965-4255 FHS Pilot
caller-id enable
voice-port 0/0/1
connection plar 5551014515
description 440-965-5351 FHS Hunt
caller-id enable
voice-port 0/0/2
connection plar 5551014503
description 440-965-5335 FHS Hunt
caller-id enable
voice-port 0/0/3
description NOT CURRENTLY IN USE
caller-id enable
voice-port 0/1/0
connection plar 5551011010
description 440-965-5701 BOE Pilot
caller-id enable
voice-port 0/1/1
connection plar 5551011020
description 440-965-5702 BOE Hunt
caller-id enable
voice-port 0/1/2
description 440-965-5821 BOE Pilot
caller-id enable
voice-port 0/1/3
description 440-965-8425 BOE Hunt
caller-id enable
voice-port 0/2/0
description FXS NOT IN USE
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager redundant-host 10.25.1.216
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.25.1.216
ccm-manager config
mgcp
mgcp call-agent 10.25.1.217 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 9000 pots
service mgcpapp
destination-pattern 9T
incoming called-number .
port 0/0/0
forward-digits all
dial-peer voice 9001 pots
service mgcpapp
port 0/0/1
forward-digits all
dial-peer voice 9002 pots
port 0/0/2
forward-digits all
dial-peer voice 9003 pots
service mgcpapp
port 0/0/3
forward-digits all
dial-peer voice 9010 pots
preference 3
service mgcpapp
port 0/1/0
forward-digits all
dial-peer voice 9011 pots
preference 4
service mgcpapp
port 0/1/1
forward-digits all
dial-peer voice 9012 pots
preference 1
service mgcpapp
port 0/1/2
forward-digits all
dial-peer voice 9013 pots
preference 2
service mgcpapp
port 0/1/3
forward-digits all
dial-peer voice 9911000 pots
preference 2
service mgcpapp
destination-pattern 9911
port 0/0/0
forward-digits 3
dial-peer voice 9911001 pots
preference 3
service mgcpapp
port 0/0/1
forward-digits 3
dial-peer voice 9911002 pots
preference 1
port 0/0/2
forward-digits 3
dial-peer voice 9911003 pots
preference 4
port 0/0/3
forward-digits 3
dial-peer voice 9110000 pots
preference 2
destination-pattern 911
port 0/0/0
forward-digits all
dial-peer voice 9110001 pots
preference 3
port 0/0/1
forward-digits all
dial-peer voice 9110002 pots
preference 1
port 0/0/2
forward-digits all
dial-peer voice 9110003 pots
preference 4
port 0/0/3
forward-digits all
num-exp 4... 5551014...
num-exp 3... 5551013...
num-exp 2... 5551012...
num-exp 1... 5551011...
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 10.25.1.254 port 2000
max-ephones 25
max-dn 50
banner motd ^C
--------------------------------WARNING---------------------------------
        This is a private and proprietary system. Unauthorized access
        is unlawful and may result in disciplinary action and/or legal
        proceedings. Any access to this system/network may be monitored.
^C
line con 0
exec-timeout 30 0
logging synchronous
line aux 0
exec-timeout 30 0
logging synchronous
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
ntp server 10.25.1.1
end
------------------------------------------------------------------------------------------DEBUG-------------------------------------------------------------------------------------------------------------------
Jul 28 05:50:21.551: //-1/6CC33C6C80E8/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=5551014500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 28 05:50:21.555: //-1/6CC33C6C80E8/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3D4F3CA4, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=5551014500(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=999000, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 28 05:50:21.555: //-1/6CC33C6C80E8/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 28 05:50:21.555: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 28 05:50:21.555: :cc_get_feature_vsa malloc success
Jul 28 05:50:21.555:  cc_get_feature_vsa count is 1
Jul 28 05:50:21.555: :FEATURE_VSA attributes are: feature_name:0,feature_time:971323776,feature_id:99
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=5551014599(TON=Unknown, NPI=Unknown))
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/cc_process_call_setup_ind:
   Event=0x2255BBB0
Jul 28 05:50:21.555: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 5551014599
   >>>>CCAPI handed cid 99 with tag 999000 to app "MGCPAPP"
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/ccCallSetContext:
   Context=0x21CDA7D0
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/ccCallSetupAck:
   Call Id=99
FHS-2901-VOICE#
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Jul 28 05:50:21.555: //99/6CC33C6C80E8/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
FHS-2901-VOICE#
Jul 28 05:50:48.564: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   remove it from the queue
1 ACCEPTED SOLUTION
Thanks for bringing up this topic.
Check this out:
https://supportforums.cisco.com/docs/DOC-27913
Hope it helps.
“If you have knowledge, let others light their candles in it.”
When I remove all dial-peers that relate to the voice-port where I put the PLAR command on, the inbound call works.
I am not sure whether you should use such long dial peer tags like "dial-peer voice 9110001 pots"
dial-peer voice 9111 can be used instead.
I have hear long dial-peer tags causing problems..
Let me know if i am wrong.
I noticed that when I have a dial-peer without the service mgcpapp command the inbound calls route just fine. What I tried doing is putting my SRST dial-peers after my mgcp dial-peers, but the problem now is that when the call managers are up, they are bypassing the mgcp dial-peers and are hitting the SRST ones.
When I do a show ccm-manager, it shows mgcp fallback mode not selected, even though I have that configured. Why aren't my dial-peers working when they should? Shouldn't the service mgcpapp command under the dial-peer only be valid when the call managers are up, and when they aren't, use H.323 (default)?
Check this out:
Hope it helps.
Hey no problem. I did look at that page and tried following the advice that was given. It still didn't solve my issue. What did solve my issue were these commands:
RemoteSite# configure terminal
RemoteSite(config)# ccm-manager fallback-mgcp
RemoteSite(config)# application
RemoteSite(config - app)# global
RemoteSite(config - app -global)# service alternate default
RemoteSite(config - app -global)# end
The problem I was having was that I was trying to enter in the call-manager fallback-mgcp, which I referenced directly from the link below:
https://supportforums.cisco.com/docs/DOC-24097
That command kept giving me an error that the syntax was incorrect. I tried entering in the service application default commands under global config mode which also didn't do anything. Once I entered in the correct command and doing a show ccm-manager, "MGCP Fallback mode: Enabled/Off" displayed. I then created my SRST dial peers which do not have the service mgcpapp command and the inbound calls worked just fine. I then brought up my call managers and the inbound calls do not hit those SRST dial peers.
I do have several questions:
1. Am I doing it the correct way as far as having seperate dial peers that do not have the service mgcpapp command?
2. Also, I have the command incoming called-number . for each of my SRST dial peers. Is that command needed if I              specified the connection plar command under the voice-port?
3. Is it recommend to have seperate inbound and outbound dial peers for the same port?
Thanks for you help so far amansin74
Re: MGCP SRST FXO Inbound Call Silence
Hi Daniel,
Just checking if you have this issue.. What is the resolution for this??
1563
