Community Member
MGCP & SRST Issue
Hi all,
I have an 1861 router configured to use MGCP & SRST for failover.
I am using 1 FXO ports which is connected to an analogue line from the local BT exchange.
I am using 2 FXS ports connected to 2 analogue telephones.
Problem 1
Within the call-manager configuration I am pointing the FXO port to exten 4002 (FXS 1) so I was expecting this to work via MGCP.
However, when I dial in via the FXO port the router answers the call & provides internal dial tone back (like a DISA line).
How do I point the FXO port 0/10 to ring the extension 4002 on FXS 0/0/0?
Problem 2
When I dial between the FXS ports the router seems to use the dial peers which I have configured for SRST failover rather than look to the call manager via MGCP.
Call Manager Ver - 6.1.2.1000-13
SRST Router - Cisco 1861 12.4 (11)
MGCP Ver - 1.0
Re: MGCP & SRST Issue
please provide the sh run from the 1861
you might be lacking the dial-peers for the ports with
application mgcp app
do they show up as registered in CUCM??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi javalenc,
The router is successfully registered as an MGCP gateway on the Call Manager with successful configuration downloads confirmed. (sh ccm-manager).The FXO & FXS ports are all registered.
Dial peers are as follows:
Voice-port 0/0/0
Station-id number 4002
Voice-port 0/0/1
Station-id number 4001
voice-port 0/1/0
Supervisory disconnect anytone
cptone GB
Impedance Complex 2
Dial-peer voice 999000 pots
Services mgcpapp
Port 0/0/0
Dial-peer voice 999001 pots
Services mgcpapp
Port 0/0/1
Dial-peer voice 999010 pots
Services mgcpapp
Port 0/1/0
Services mgcpapp
Port 0/0/0
Dial-peer voice 9 pots
Destination-pattern 9……
Port 0/1/0
Destination-pattern 90……….
Port 0/1/0
Dial-peer voice 4002 pots
Destination-pattern 4002
Port 0/0/0
Dial-peer voice 4003 pots
Destination-pattern 4003
Port 0/0/1
Community Member
Hi javalenc,
Voice-port 0/0/0
Voice-port 0/0/1
voice-port 0/1/0
cptone GB
Impedance Complex 2
Services mgcpapp
Port 0/0/0
Services mgcpapp
Port 0/0/1
Services mgcpapp
Port 0/1/0
Services mgcpapp
Port 0/0/0
Port 0/1/0
Port 0/1/0
Port 0/0/0
Port 0/0/1
Try adding this
voice-port 0/1/0
connection plar 4002
That will stop the secondary dialtone when you call the number associated w/the FXO port.
Hope that helped.
The info above is good from Ken ...5 pts for you! But if you dont always want it to go to that extension and want to maintain your DID capabilities use the command "direct-inward dial" under your FXO pots dial peer.
if this is not a typo in your original post:
MGCP Ver - 1.0
then the issue is that Cisco supports version 0.1
i just noticed that info in your post, all the example guides show that you should use version 0.1
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
mgcp call-agent 172.16.240.124 2427 service-type mgcp version 0.1
javalenc
java
Community Member
I will change back to MGCP ver 0.1 & let you know.
I have already tried the PLAR and PLAR OPX configuration in conjunction with the FXO port but the problem I found was that when I answered the call on the FXS port I could then hear the DTMF tones for 4002??
Thanks for your help.
238
