Community Member
MGCP SRST router config question
Hi all. Im about to ship out a 2811 MGCP SRST router to the remote site. I have testing it out and all works well. But, today I got some other IP information for another MPLS circuit on that router. I put in the config for that particular controller/port and Im wondering if when the SRST router comes up and registers with CUCM, will it overwrite that part of the config I did for the extra MPLS circuit?
Re: MGCP SRST router config question
SRST only creates the virtual voice dial-peers to route the calls, it has nothing to do with MPLS config
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
ok, sounds good. didnt know that, but now I do. Thants helpful. I appreciate it.
126
