MGCP-SRST
I am trying to expand the incoming number and add a prefix under srst configuration. I have the translation pattern applied on the pots dialpeer. Call doesnt seem to hit the dialpeer on inbound and hence the translation. Applied the TP on the voice port with same result. The test trasnslation rule shows correct results, adding the prefix. Any ideas ?
Applied translation profile on inbound side of the pots dialpeer.
Thank you,
Hall of Fame Super Gold
Re: MGCP-SRST
With MGCP, translations and DPs have no effect.
Re: MGCP-SRST
Are you trying to perform the digit manipulation when the router is registered as an MGCP gateway or when the MGCP endpoint
falls back into SRST mode?
-Felipe
Re: MGCP-SRST
In SRST mode.
Re: MGCP-SRST
Can you paste your Translation Profile and Translation rule config. Also, take following debugs to check which dial-peer is getting matched as inbound dial peer and if translation is taking effect.
debug voip ccapi inout
debug voice translation
362
