Community Member
MGCP vs H323
What are the advantages/Disvantages of having MGCP configured compared to H323. How difficult would it be to convert?
Re: MGCP vs H323
we already have a doc on that:
MGCP and H.323 Voice Gateway Protocol Comparison
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00806fedbe.shtml
MGCP is easier to configure but has limitations because CCM takes all decisions and only works on DNIS.
H323 requires more configuration because of dial-peers but work with ANI, DNIS and redirect number. you have a lot more control.
it's really not that hard to convert between them, a GW can have both at the same time if you want to handle a PRI with MGCP and other with H323
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: MGCP vs H323
If MGCP is configured on the CM what function does the publisher have in the operation. Also, where can I find information on how to configure H323 on the gw?
Re: MGCP vs H323
CM takes all decisions of routing, MGCP is master-slave, H323 is peer to peer. have you gone thru the link? that is explained there
Cisco IOS H.323 Gateway Configuration for Use with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Cisco IOS H.323 Configuration Guide
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_h323_configuration_guide/old_archives_h323/323confg.html
Dial Peer Configuration on Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
more links are available if you search H323 on CCO.
javalenc
java
Community Member
Re: MGCP vs H323
thanks
Community Member
Re: MGCP vs H323
Q is this a correct statement
The main reason I would use MGCP over h.323 is for failover.  If you are using a h.323 gateway and your primary callmanager goes down the calls will be dropped.  With mgcp the gateway calls will be failed over to the secondary callmanager and the calls will stay up.
According to H.323 gateway confg
There is 2 VOIP statements apply with a
Session target ipv4: Primary Call manager IP address
And Subscriber IP address
Can you explain?
Thx
522
