MGCP with PRI
Dear sir
I wannted to know that i m using MGCP with 2 PRI's . i want to fix some channels for inbound call and same for outbound call on PRI 1 same thing with my PRI2. is it possible if yes how ? and same with H.323 ?
it will be very appreciating for me
thanks waiting for yr prompt response
Re: MGCP with PRI
you can choose which way it hunts for an outbound channel - from top down or bottom up - so it will start hunting at ch1 or ch23
your provider selects which channel the incoming call is on
Re: MGCP with PRI
sir
cannt we select channels in mid for outbound calls, for example ch5 to ch15 etc ? or can we select channels start from ch1 to ch10 for outbound. and ch11 to ch 23 will remain for inbound ?
yr response will really help me alot.
Hall of Fame Super Gold
Re: MGCP with PRI
Hi, you asked this question on other threads already, but you never clarified why or what problems are you trying to solve.
118
