Community Member
MGCP
hi i need to configure MGCP for voice in my remote oficce using FXS and a Callmanager 4.0 can someone suggest a config.
1 REPLY
Community Member
Re: MGCP
The best way to do this is to put the following lines in your router
mgcp
ccm-manager config server
ccm-manager config
The ccm will then automatically download the config that you insert in the gateway config page.
You may want to disable music on hold as this can chew up a lot of bandwidth.
141
