Microsoft dialer
balitewiczp
Level 2
Level 2
I am looking for software which will allow me to dial directly from outlook contacts using my cisco phone. I am using CM 4.1.3. I have found the TSP integration with Microsoft outlook, but it only references CM 3.X. Is there a newer version of this? thanks
mchandak
Level 7
Level 7
TSP Software for CallManager is available with all version of CallManager. It is bundled with CallManager and the upgraded version is available from the Plugins download page on CallManager Admin page.
Hope this helps
mchandak
Level 7
Level 7
Hope this helps
pmuller
Besides TSP you can check out:
http://www.netelligent.com/products/dialer/default.aspx
There are both free and paid versions available. They are both less CPU intensive, don't require TAPI on the desktop, and don't require updating when upgrading CCM.
Hope this helps.
